Speedometer not working.
Old Oct 22, 2011 | 09:18 PM
Yotaguy0001's Avatar
Hello. I just recently purchased a 1992 4runner SR5 V6 auto transmission. The speedometer doesn't work. The odometer, and tripometer do though. First off from what I've read, I believe the vehicle to have an electronic speed sensor, and not a cable operated speedometer. Does the vehicle speed sensor control the odometer and trip? If so, that leads me to believe the speedo head is hanging up. What's happening is that the speedo basically doesn't work, but sometimes it spikes to 40 and just stays there. Any help would be greatly appreciated. I already have the link to the FSM. Thank you.
Old Oct 23, 2011 | 06:38 AM
scope103's Avatar
The VSS (electronic speedometer sensor) drives both the speedometer and odometer (and the cruise control and some ECM functions). So if your odometer works, your problem is in the instrument panel.
I've never worked there, but "spikes to 40 and just stays there" sounds like a mechanical problem -- like a bent needle. Alas, the needle is driven by a stepper motor, so you may run out of simple repair opportunities.
Good luck!
Old Oct 23, 2011 | 02:19 PM
Awesome! Thank you for the feed back. The cruise control works as well. Is it possible to just change the speedometer head? Or does the entire instrument panel have to be swapped? I just want to get as much info as I can before I tear it apart. I'm used to working on diesel trucks; I find them much easier to work on than consumer level cars and trucks. Thanks again.
Old Oct 27, 2011 | 04:19 PM
zero503's Avatar
You might be able to open the cluster and swap out the speedo, if thats the issue, i would just find a whole one to swap out tho.
Old Oct 27, 2011 | 07:09 PM
There is a place around my house that deals with only toyota's they will probably have it. The speedo has been working as of late, so it's a odd issue. Got to be a bad speedo head. Thanks again
Phantez
Sep 30, 2015 08:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Rickstwowheels
Sep 21, 2015 05:21 AM
matt1833
Sep 16, 2015 07:11 AM
toyotafreak98
Sep 10, 2015 02:57 PM
