- Surf starters?
- 3VZ idles up & down
- Injectors for 91 3vz-fe?
- Fast idle screw makes no contact, wrong screw?
- 1991 4runner cooling fan exploded
- Leaning...Broken Tension bar??
- No wipers/washer this morning??
- Speedometer is not workin in 1987 4runner
- Timing set correctly, but dizzy almost maxed?
- Overheating Issue
- Headers and their gaskets
- let talk about exhaust
- Oil pouring out front of motor 92runner v6
- CB radio install suggestions/pics
- fuel injector plugs , 22re are all 4 the same
- How to: Add a headlight buzzer alarm (w/ pics)
- $300 to blow: suggested options?
- CNG Conversion
- Starter issue
- Brake pedal rock hard when turned off and now...
- 94 Ext. Cab
- NO power to b+ in diagnostic box
- steering linkages
- Crazy high idle when cold.
- Brand new 22re?
- 94 Sas x-cab pickup parts...
- Could these two cel codes be related??
- Multiple issues with 87 p/u: bogging out, low mpg, stained drive way...
- 89 22re Tensioner Pulley help plz
- a testiment to toyotas strength
- replaced starter on 90 22re,still no start
- B+ to fp failed help??
- blowing "stop" fuse
- no 2 speed sensor
- 91 deluxe 4x4?
- sold my 1st gen ;( but got a 2nd gen ;)
- 22re timing setting
- Checking for Water Damage
- Aftermarket Intake Manifold?
- built 89 4runner, keep it for a work truck or sell it and start searching?
- Toyota 3vze Low Compression
- Difference between these 2 descriptions?
- 1994 reg. cab only has rear brakes
- Throttle sticking!!!! DANGEROUS!
- Got headers...need exhaust system!
- Smog/ Emissions
- Anyone know: accel dist cap?
- Rear Axle Seals/Bearings Write-up
- fuel pressure regulator ?
- Need help identifying this part (3vze)
- 4 runner seats
- common problems
- OD and speedo problems?
- 22RE Cylinder head integrity....
- Electrical problems?
- Replacing all the vac hoses on 90 V6 runner?
- 89 Runner I picked up today, idles weird & missing [video]
- Unfixable oil leak??
- Threw a rod
- 4cyl Rearends 2vrs4
- 92 2wd p/u Hardwire o2 sensor question
- 3.0 V6 Fan Bracket replacement Write-up
- Transmission Fluid/ Filter Change
- 87 rear axle compatibility
- Newbie question, fuel tank pressure??
- no high idle when cold
- clutch
- help with 95 3 liter
- Tacoma door panel
- rear window up or down when off roading?
- Rough Country question
- 1989 22RE auto to manual swap HELP!!
- Cold Start Switch covered in oil???
- Vibration when I let off after LC/spacer lift
- 92 Pickup Dash Cup Holder Where Can I Find One???
- Trouble codes
- Do I need shackles?
- Alternator?
- ext cab wheelbase?
- battery cable burning
- Defroster related to A/C Compressor?
- Help securing my 87 4runner
- 22r vacuum advance kind of works?
- Auto 4wd 3vze 1990 4run trans cooler re-install
- 15amp fuse keeps popping!
- Hidden Coolant Leak
- Dumb brake line question, not size.
- What is this wire/plug?
- Stalling issues
- 87 4runner temp problem
- 88 4x4 p/u brake line size
- what seats will bolt right into my 90 extended cab pickup?
- Turbo RET Injectors on a built 1986 22RE for extra juice?
- Marlin Crawler bushing install
- help how to get timing gear and chain on
- The csi issue
- Wrong Shift seat?
- Help finding correct TPS
- Got my seat covered!!
- Igniter question
- 94 v6 problems?
- 4runner will not start, fires then dies, HELP!
- apply gasket sealer to head gasket on 22r
- cold start issues
- Question about building my 93 Toyota
- KISS front bumper idea-looking for pics of similar bumpers
- enigine mount on a 22re?
- White Smoke
- driveline alignment, ext-cab truck
- New windshield and trim for my 88!
- Rear Sag
- 3.0 auto trans problem
- TPS Problems... Maybe?
- Low voltage to fuel pump
- Adding to my existing lift
- Leaf springs swap?
- Check engine light
- 91 3.0 swap
- 22re rough idle and acceleration after TPS changed
- Quick Question: energy suspension bushings install
- Engine wiring harness info.
- rear main seal leaks
- Bushwacker cut out fender flares????
- Automatic Transmission Sluggish
- 3vze wiring help needed. Mystery Wire
- 93 DLX w/ 3.0 Engine Swap Information
- tv4184 style interior re-coloring
- flatbed tailer lighting
- Bilstein bushings and washers
- Front end compatability
- 1989 22RE bad mpg during city driving or cruising speeds
- Will Break pads from a 92 pick up fit in my truck
- Air gurgling through heater core: 92 runner with 3vze
- Bed storage
- Hello From A New Guy
- heater on ignition all the way off
- 1st gen 89 cluster lights no worky
- '91 3VZE tranny swap
- 22r rebuild crankshaft seizing
- pulling a 3.0 manifold
- Header recommendations??
- 90 .3 auto shifting problem... I think???
- timing chain cover problem
- 1994 Toyota 3vze acceleration problems + bad compression
- 88 wont start. Carb?
- Fix it up again or move on...92 4runner
- looking for opinions
- 3.0 Cat Converter - Poor fuel mileage
- alternator glowing red hot
- 88 4runner oil in coolant
- What color for paint
- Starting problem with 1992 toyota pickup
- Fuel filter in backwards?
- 93 4runner back drivers side coolant leak
- 89 Toyota P/U Headlight Wiring Upgrade Build
- Radiator Cap problems
- auto trans problem
- croatia 4runner
- Left turn clunking/shifting sound
- 88 3VZE 5 speed harness question
- Ignition coil help???
- fuel sending unit ?
- Pro comp coils?
- Electric Fan Install Pros/Cons
- Air in Brakes after bleeding
- 22re swap
- '89 22RE knocking in top front of engine
- Anyone with driveline vibes after LC coils?
- 92 4runner wont start after sitting for 5 hours
- A/C Cold then Hot then Cold...
- New Project
- Idler Arm Ball Joint Wear?
- 22re oiling problem
- front pinion bearing removal
- Crank shaft pulley loose
- Truck no longer idles, need some help *pics*
- 4 wheel drive quits
- Electrical "Ticking" noise tied to RPMs...what is it?
- Gas Mileage????
- Anybody on who can help with a quick ball joint spacer ?
- 4 Low Grinding Sound?
- cold start circuit wiring
- how to put distributor gear back on
- 91 standard cab 4x4 5mge swapped electrical problem.
- Starter switch problems?
- 91 4runner weird timming
- Back to the Future
- cold start timer plug
- lspv on 1986 truck
- 4runner won't crank, no click, good battery
- 3.0 issues
- Return to idle problem
- Having major work done on my 1991-what am I forgetting?
- 1991 Pickup-Exhaust rotted from manifold flange to tip-cheapest replacement?
- To rebuild on not to rebuild , advice please
- Low idle on 88 4runner?
- 1989 22re 4x4 pickup will not idle when warm
- 3VZE Idle Speed Control Valve
- 1997 22R Carb Issues
- EGR Temp Sensor??? Please read and help!! :)
- Odd brakes....?
- 3.0 warm-idle is cycling
- Just need some imput on my 92 runner
- 22RE Vacuum Line Sizes
- Winch Solenoid Mounting Locations
- need owners manual not tech manual
- Where to connect RPM meter on 3VZE?
- No. 2 Speed sensor replacement
- Cooling issues
- Part on drivers side engine below exhaust - ?
- 90 SR5 4Runner parts into 93 Std. Cab
- Tranny Started making noise....
- I found my coolant, but not the leak.
- 22re gremiln, wierd idle thing
- 22re engine codes 25 and 52
- cold start timer switch
- No spark, fuel spitting out of exhaust manifold on the downpipe
- V6 - single 4.7 transfer, anyone put twin sticks in?
- Help with acceleration issue.
- Clicking noise
- Temp And Oil Gauge Problems
- grill question
- 1994 4runner idle is rough
- grill/headlight swap
- 4x4 engaged--lots of drag in reverse
- Completely stumped
- Mystery misfire when warm only
- Rust or Engine
- 88 wont start.
- Oh no not rust!
- new TPS on the way anything else i can look at?
- What is the Quality of NWOR complete differentials
- Starter getting hot and wire to battery smokin...
- tailgate hinge rattle
- idle question
- 1990 Toyota Pickup Not Shifting To 4th Gear Easily On Freeway Right After Cold Starts
- Braking issues
- 93 runner question
- Thinking of upgrading gears 4.56
- 1988 Pickup Xtra Cab Trans Problems
- Sticky Gas pedal and heater controls!
- '90 22RE p/u 2&3 cyl not firing
- Lock Rite Locker with stock geared 92 4x4 w/ 31x10.5's
- 1990 pickup: no power over 1/4 throttle 22RE
- Fuel Problem??
- Lots of Lighting in the Planning Stage ... Need help from the Pro's!
- Rebuilt my fan clutch (running too cool now?)
- Factory Cruise Control Install
- Gearshift will not move when on. Only when off?
- electrical guru help: power windows always working
