Could these two cel codes be related??
Old Feb 29, 2012 | 08:05 PM
90_4x4's Avatar
Code is 42 for the VSS, and code is 12 for RPM signal... Could these two be related? It's weird because I swapped out my cluster for another one to check to see if the problem was in the cluster and still got both codes after ecu reset. My speedometer works and my tachometer works also my distributer is less than a year old. Any input? Could my ECU just be going bad? I pulled it just to look for any signs of water damage or leaking capacitors and everything looked great. So idk where to start.
Old Mar 16, 2012 | 11:56 AM
90_4x4's Avatar
Any ideas, I'm still trying to figure this out!!!
moparbay
Mar 10, 2023 03:50 PM
Longbed 90
Mar 11, 2019 12:38 PM
Ronnyboy
Feb 11, 2016 05:57 PM
Dobich
Sep 14, 2015 11:15 PM
larrys93pickup
Sep 6, 2015 06:37 AM
