1989 22re 4x4 pickup will not idle when warm
Old 02-18-2012, 04:05 AM
hayconc's Avatar
My 1989 5 speed stalls just about every time you put it in neutral or let off the gas when warm. when this happens I hear a clicking sound in the dash glove box area. Any thoughts or solutions would be greatly appreciated!
Old 02-20-2012, 01:54 PM
abecedarian's Avatar
Warm it up, then adjust the idle and timing so it runs properly.
Once you get it idling properly warm, it's time to troubleshoot the cold start / idle issues which most likely caused adjustments to the warm idle settings, and consequently caused the warm idle issues.
Old 07-29-2013, 11:27 AM
muddmadness's Avatar
Warm Idle issues
I am having the same issue with my 22RE, I have replaced the cold start injector, the temp sensor switch, adjusted the Throttle position sensor, attempted to advance the timing with the jumper wire and I have done a valve adjustment and still no change in the warm idle problem. Frustrated to say the least, I don't know what else to do It only wants to die out when it is warmed up and has problems starting. Any suggestions?
Sandman
07-23-2015 08:15 PM
sonic concepts
07-01-2015 02:33 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
89-4run
09-05-2002 08:15 AM
Fred Anarat
12
08-27-2002 04:50 PM
Quick Reply: 1989 22re 4x4 pickup will not idle when warm
