1989 22re 4x4 pickup will not idle when warm
Old Feb 18, 2012 | 04:05 AM
hayconc's Avatar
My 1989 5 speed stalls just about every time you put it in neutral or let off the gas when warm. when this happens I hear a clicking sound in the dash glove box area. Any thoughts or solutions would be greatly appreciated!
Old Feb 20, 2012 | 01:54 PM
abecedarian's Avatar
Warm it up, then adjust the idle and timing so it runs properly.
Once you get it idling properly warm, it's time to troubleshoot the cold start / idle issues which most likely caused adjustments to the warm idle settings, and consequently caused the warm idle issues.
Old Jul 29, 2013 | 11:27 AM
muddmadness's Avatar
Warm Idle issues
I am having the same issue with my 22RE, I have replaced the cold start injector, the temp sensor switch, adjusted the Throttle position sensor, attempted to advance the timing with the jumper wire and I have done a valve adjustment and still no change in the warm idle problem. Frustrated to say the least, I don't know what else to do It only wants to die out when it is warmed up and has problems starting. Any suggestions?
sonic concepts
Aug 16, 2025 03:13 PM
Sandman
Jul 23, 2015 08:15 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
89-4run
Sep 5, 2002 08:15 AM
Fred Anarat
12
Aug 27, 2002 04:50 PM
