Fuel filter in backwards?
Old Feb 20, 2012 | 03:16 PM
California's Avatar
I just changed my fuel filter, and I am glad I did. I followed the instructions here: https://www.yotatech.com/forums/f116...ctures-218962/
They were very helpful - I love this site.
So, when I got under there I noticed that the filter bracket was not attached to the frame of the vehicle - the bolts were gone! Then I inspected more closely and I realized that the bracket was upside down and couldnt have been bolted in because it wouldnt line up... then I realized the old filter was on backwards... The whole assemby was just hanging there!
I removed the filter bracket & filter, and installed a new filter and bought some new bolts and attached it all up correctly and everythings great now.
My question: can a filter be used backwards? should I be worried that the fuel hasnt been filtered correctly?
Old Feb 20, 2012 | 03:33 PM
Terrys87's Avatar
I have seen them in backwards before. I wouldnt be worried about the fuel that has already been run thru it. I think you would of have other problems if it was really contaminated going thru the filter.
Old Feb 21, 2012 | 07:18 PM
scope103's Avatar
If you use the filter backwards, it "unfilters" the fuel, making it even dirtier.
Just kidding. The filter has a "correct" direction where it will work better, but if your vehicle is running well now with the filter on the right way, you're almost certainly in the clear.
Old Apr 9, 2012 | 05:52 PM
andrew1586's Avatar
The in side comes from the tank
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
