Transmission Fluid/ Filter Change
Old Feb 27, 2012 | 08:25 AM
lv934runner's Avatar
Been searching for some help with my 93 4runner V6 4wd auto. Went on a trip and the next morning trans started slipping severely. Had truck towed home on a flatbed. upon delivery truck grabbed gears for a few seconds then resumed slipping. I dropped trans pan to replace filter and apx 10 quarts fluid come out. all the threads I've seen say there should only be three or four quarts present. Anyone have any thoughts? By slipping I mean will not budge at all. Thanks for any help!!!!
Old Feb 27, 2012 | 10:37 AM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b...27descript.pdf
drain and refill: 4.5USqts
total: 10.3USqts
Thanks to your careful measurement, my guess is you have a leak in the torque converter. As much as I prefer to do my own work, I think I'd defer to a real Transmission shop for that.
Old Feb 27, 2012 | 10:54 AM
Thanks for the response. I am new to the transmission arena. Is that a common problem to have the torque converter leak? I am afraid I will be doing this repair myself and I just want to approach this with my guns loaded so to speak..
Old Feb 27, 2012 | 01:17 PM
alltracman78's Avatar
Not that common.
If you can remove your transmission you can replace the torque converter.
Remove transmission.
Slide the converter out of the trans.
Slide new converter in [make sure it goes all the way in, you may have to play with it].
Reinstall trans.
Old Feb 27, 2012 | 01:19 PM
You may end up needing a new trans anyways, once you start slipping the clutches you may burn them up.
Old Feb 27, 2012 | 01:28 PM
If on a tight budget. what steps would you take/recommend? It was the large amount of fluid that drained from the pan that has thrown my reasoning out. I drained almost 10 quarts. I have driven only a couple of miles since it started slipping and had it towed home. Could it be the pump? Once again thanks!!
Old Feb 27, 2012 | 01:32 PM
It looks like the entire capacity of the trans is only 10.3 quarts, meaning the entire content of fluid resided in the pan. Had fluid levels checked recently so overfill is unlikely. Thanks
Old Feb 27, 2012 | 01:46 PM
It may be your pump, if you want to really check it out you'll need pressure gauges to hook up to the trans.
Old Feb 27, 2012 | 02:06 PM
Thanks for the insight. I 'll check pressure at the cooler and post the results. If you think of anything else please let me know.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Jul 27, 2015 09:58 AM
ryerye13
Jul 14, 2015 08:27 AM
madxman21
Jul 9, 2015 10:26 AM
