cold starting issues 22re
Old Feb 13, 2012 | 01:18 PM
rjc's Avatar
rjc
hi guys i'm new to toyotas and i have a starting issue.Its a 88 4x4 22re.Its been starting and running fine and yesterday it was below 0 and it turned over and fire but would not run. after about ten minutes it fires up and runs.did the same thing today.i kept trying it today every couple hours and would run fine.any ideas
Old Feb 13, 2012 | 01:27 PM
James Woods's Avatar
Look into the cold start injector system.
Old Feb 13, 2012 | 01:34 PM
rjc's Avatar
rjc
where would that be located? I,m also getting code 51 switch signal
Old Feb 13, 2012 | 01:48 PM
Code 51 has to do with your TPS which can cause drivability concerns like hard starting, rough idle and so on.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Feb 14, 2012 | 02:30 PM
rjc's Avatar
rjc
thanks i'll mess around with it this weekend
Old Feb 21, 2012 | 03:41 PM
rjc's Avatar
rjc
well adjusted the tps no more code 51,but no real cold weather to see if it still have a starting fit.thanks James for the info.
Old Feb 23, 2012 | 12:02 AM
ogjohnboy's Avatar
the cold start injector doesn't necessarily imply its for cold weather. its for when your engine is cold (as in hasnt been started yet).
jennygirl
Nov 17, 2015 11:24 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
scott
Jul 15, 2002 07:56 AM
