- CAMel toe
- 3VZE Headgasket fix up and running again
- 600 rpm idle but...
- MPG w/ 3.0?
- Unusually High Comp. In #5
- Thermostat question for gurus of TOyota
- Rear spring options
- Converting to Manual Hubs 1987 4Runner
- Clutch or trans trouble,'89 2wd 22re
- Spuddering engine
- Blown Hg 22re
- Water Pump?
- 22RE Milky Oil...
- w56 behind 3.slow?
- Oil leak on 22re
- A340E x-fer case will not engage! HELP bigest snowstorm in 3 years!
- Clips for brake pads
- wont rev past 2000 rpms
- 89-95 Pickup front bumper
- drivetrain issue
- Round eyes head light conversion
- What to do with 4 or 5 thousand dollars
- 22R valve train noise question
- new truck...
- torsion bars???
- Engine stalling.
- Swapping out 80s 4runr tailgate setup
- 22re - Nippon head reviews/Cam suggestions
- Anyone in Vegas want to do a junkyard run?
- Head flange - Is this a problem?
- fuel filter ?
- Help Quick! No Start.
- Tire advise
- Auto gen1 Body Lift?
- 86 4 cyl AT 4.30 and 33X12.50 good or bad?
- HELP! Grinding problem that I can't figure out!
- Anyone seen this?
- TRD rear end into a 92
- Sloppy Rear End...
- 1st gen AFM on 2nd gen 22RE
- is 3VZE <--> 3VZFE Distibutor the same?
- Thats it!! exhaust manifold leak
- 22re torn down, can't find the problem
- Need help, Jammed Dizzy
- running with no CVs
- Wobbly PS pulley- what's the worst that could happen??
- Rear Tire Carriers
- Door Speakers!
- Burning but not Smokin'...good/bad?
- Dealership wants 4500$ for a few repairs
- What size tire?
- How far can I take it off road
- body lift installed
- Speakers in Rear of 4runner
- 3.0 Fuel injectors/ Head gasket
- ECU Problem Need Help!!!!
- Bunch of noobish stuff (shoot me)
- steering wheels
- broken tab on e-brake handle... replacable?
- 3vz-fr?
- Pro Comp ES3000 or ES9000 with 2" of lift?
- LCE finally admits their exhaust wil work with the 3vze
- 88 3.0L wont start, no fuel
- Queston about running 35's
- AT Oil Temp Light
- Horn honks when car is not on, then catches on fire
- rotors
- Steering Assist Question
- ECU pinout verfication; Knock Sensor; CEL 12
- Steering rebuild
- 22re idleing issue
- Safari snorkel
- keeps blowing fuses
- 91' FI PickUp rotates but won't start.
- rear panel fiberglass for my 94 4runner
- Power steering belt keeps up!
- tube bumpers
- 2nd Gen 2 Door 4Runners....
- cv axle falling out
- won't start!!!!!!!!
- Fooling your 02 sensor
- hard to shift into 4-Hi ?
- 87 4 runner turbo poor heat!!!
- Help! Fuel system woes! Warning: Long
- My Blank Canvas
- Do these look like crap?
- Advice on lockers
- Learning queston
- Broke down in the '86 yesterday...gathering input
- 87 Pickup Engine Rebuild 22R
- Truck starter problem??
- 22re issues after rebuild......
- Header gaskets
- Help me wire up my new o2 sensor
- what is YOTATECH nicest 2nd gen 4runners POST THEM
- Dead useless truck right now
- repair leaky brake booster?
- New coils and shocks on!
- 2 questions.
- Need some advice on exhaust
- Is there a good tranny mount??
- Rocksliders VS Chains and Misc.
- Starter Differences '93-'94?
- Squeal on startup
- 31's to 33's
- re-tread tires ?
- Chrome bumper ends for 86'
- whine
- radiator hose leak
- Interesting day!!!
- code 26 and lumpy idle
- Is the 3.0 really THAT bad?
- engine code 51?
- Tranny Kickdown Cable
- help me get to work tomorrow
- my 91 sr6*
- bad miss
- Pro Comp Light Bar
- NuBe CEL Question
- 22re - drove it home, and now nothing happens when key is turned
- Setting up T-bars for install-does this look right
- Popping rear in side pannels off a 1995
- 1989 0r 1990 toyota pickup?
- interior manufacturers ?
- suggestions for interior panels,upholstery
- *searched* 4x4 wont engage ADD
- Aftermarket intake manifolds?
- Need answer ASAP selling truck this morning
- Back seat release knobs
- New Distributor /Plug Colors Don't Match...need help
- back window again
- smog question and fun in the snow!
- Which Tru Trac model for IFS diff?
- low compression #2 cyl v6
- Pillar Rust
- Rear Defrost Repair Help
- O2 sensor, What wire goes where?
- Drivers door
- Engine Switched Now No Spark
- Engine swap advice
- NEED HELP FAST (Rear DE-FOGGER)
- Mounting Spare Wheel / Tire to Roll Bar!
- Water Pump
- 91 4runner starving for air!
- which wiring harness should i use??
- Custom Speedo
- Raybestos Clutch Hose
- Found the oil leak--oil pan removal?
- Knock Sensor 86 22RE (Code 12)
- flashing cel?!?
- Digital Speedo
- New guy, figured I would share my rig, with pics.
- New Timing Chain, still Startup rattle
- parking light into turn signals
- Not to cold for CB install!
- Q about seafoam
- oil cooler
- In need of more help on the 4runner
- Tranny Help !!!!
- 91 3vze compared to 94 3vze
- 4Runner body on truck frame swap
- Lowering Kit
- Vacuum Hose Question
- Found my GREMLIN in the 91 Runner
- wondering that this part is called
- 1st gen roll bar 2nd gen 4runner install with pics
- tires
- good exaust for 3.slow
- replaced thermostat,now what?
- FJ40 for 88 Runner trade, should I?
- Broken Body Mount
- Tail lights on a custom bed?
- Rear Window Swap
- oh no!!!
- Best way to resurface head/block
- real dual exhaust on a 3vz
- body mount hardware grade
- Rough Riding 4X4 Yota Pickup........HELP!!!
- where is the dash fuse that runse the speedo/gas/temp light?
- Aussie Locker - Ease of install?
- o2 sensor welded?
- used ock outs
- wont run after hg replacement
- Show us your Camo Paint job
- knock sensor question.
- painting 88 Runner with spray balm - anyone?
- URGENT! Help Replacing CV axle (95 4Runner)
- ? for you guys with 1st gen roll bar in a 2nd gen 4runner
- injector boots
- 1991 4runner poor fuel economy
- This sucks (Got Downey Bikini top for X-mas)
- About to embark on a project... quick advice.
- teaser video
- results...
- Brake Fluid Cap
- Turbo Brake Components
- Setting F bearing preload on the bench?
- Downey Rear Spring ?'s
- Help! '86 4wd pickup, really poor gas mileage, no power in high gears
- rear window wont go up HELP!
- Body Dmg, how much to repair?
- 22R Carb Options
- 91 yota tach questions
- im stupid....what does SAS stand for?
- Car locks when i turn the key...
- 90 4runner, another brake problem
- S10 Leaf Swap?
- Speaker Options in 86-89 4Runner
- W56 rebuilders: watchouts?
- No Power Steering
- Help: Crankshaft Pully Bolts are frozen on!
- Which O2 Sensor?
- Some new pictures
- Cold "hooosh"... brake booster?
- Will 12.5" Tires Fit on Stock Rims?
- Head Gasket Vs. Rebuilt 3.0
- Warn front bumper for toyota _________?
- 22RE: Early to late intake swap
- Need advice on 3" Suspension Lift for '95 Toyota Surf
- Flares...Yes or No?
- Extended Stainless Brake Lines - Cheapest Source?
- Water still in exhaust after submersion?
- interesting 22re miss.
- Clutch Installation
- 90 runner 4 inch lift 33s?
- Broken exhaust
- What is wrong with my...
- compression test
- what did i just break? my axle?
- O2 sensor wire 86 runner
- stock gears & 33's
- Aluminum to Iron Head Swap & other concerns
- transmission removal 22RE w/W56
- coolant leak
- fiberglass fenders???
- Missing converter cover
- Big, intermittent oil leak in 3.0
- difficulty and best source for a posi/LSD rr diff?
- rocker arm replacement w/o removing cylinder head
- Price for clutch job
- 95 22re p/u won't start when warm
- Where to get cheap O2 sensor for 94 runner
- 89 4Runner Suspension
- Ok good or bad???
- Looking for OE wheels
- I need to buy a fuel pump bracket - where do I go?
- Hanging starter, dead battery a few times, other wierd elcectrical gremlins perhaps?
- XMAS eve 22RTE party!
- Auto to Manual Hubs - What do I need?
