interesting 22re miss.
Old Dec 27, 2007 | 12:24 AM
skife's Avatar
driving down the highway today at around 70ish, 2800-3000 rpms and the check engine light turns off, randomly and when it does the truck misses, it comes back on and the truck misses. puzzled me abit.
on the way home the truck missed about every 30 seconds, it was a quick miss, i'm thinking it wasn't getting spark because it would make a backfire noise after it would miss.
can anyone point me in the right direction.
truck is missing the knock sensor, could this have anything to do with it.
Old Dec 27, 2007 | 04:30 AM
ozziesironmanoffroad's Avatar
kind of sounds like an injector had different plans than you did today.
Old Dec 27, 2007 | 07:09 AM
thook's Avatar
If there's no knock sensor, that's likely to be the cause for the CEL. Plus, you have big hole = vacuum leak that needs to be plugged up right in the manifold. If it's just the wire missing, you'll need to fix it. In either case, the ignition timing is going to be affected and either could be (and probably is) causing the backfiring.
There are two types of backfiring. One is from the exhaust manifold and the other is back up through the intake. Neither are good, but the second is very serious.
Old Dec 27, 2007 | 07:50 AM
HairyTheWombat's Avatar
agreed, I lost my last 4x4 (1976 full size cherokee) because it would backfire through the intake and one time it set the engine compartment on fire.
bye bye cherokee!
Old Dec 27, 2007 | 10:38 AM
skife's Avatar
knock sensor threads into the side of the block.
Old Dec 27, 2007 | 11:11 AM
elvis's Avatar
Clarification; the CEL light is on at all times; and went out when it misfired?
truck is missing the knock sensor, could this have anything to do with it?
I may be mistaken; but will a missing Knock Sensor keep the ignition timing retarded and in open loop?
Anyway; my guess: A cool high humidity day and you were under load. Moustier in the cap; causing a cross spark.
Old Dec 27, 2007 | 11:16 AM
skife's Avatar
it was night time and about 35ish, so the snow was melting and stuff... hmm
Blamalam
Mar 12, 2022 07:34 AM
Sleaker
Aug 26, 2020 06:03 AM
JNapolitano
Nov 14, 2019 07:46 PM
Michael oaks
Jul 27, 2015 11:47 AM
