which wiring harness should i use??
Old Dec 31, 2007 | 08:10 AM
89pickupsr5's Avatar
I have an 89 p/u that i am putting a 3vz from a 94 4runner into which wiring harness should I use?
Are there any differences besides the tensioner and fan bracket?
When I got my rebiuld kit there was a difference in price from 88/92 to 93/95
they are both 4wd
Thanks, Drew
Old Dec 31, 2007 | 08:46 AM
mt_goat's Avatar
You will probably need to use the harness that matches the ECU. If you are using the 89 ECU you will need to use the 89 engine harness and most likely the 89 sensors too. Toyota made changes to the ECU pinouts over the years, in some cases the engine harness will still plug in to the ECU but will actually be wired WRONG.
Old Jan 1, 2008 | 05:08 AM
cool thanks man. thats what i was wonderin'. do you think i'll have splice anything?
Old Jan 1, 2008 | 05:51 AM
mt_goat's Avatar
I kind of doubt it, as long as you use the 89 harness, 89 ECU, and all the 89 sensors. In other words, just swap the 94 block and heads in.
Does your truck and the donor truck both have oil pressure gauges? If not, you better keep the oil pressure sender from the original engine. It should just screw in place of the 94 sender.
Old Jan 2, 2008 | 11:13 AM
what if i was getting a new sender??
Old Jan 2, 2008 | 11:18 AM
mt_goat's Avatar
That's fine, just get one that matches your gauge, if you have one. Some trucks have gauges and some have idiot lights and the senders are different.
Old Jan 4, 2008 | 01:34 PM
ya ok thanks alot man
80Truck
Oct 12, 2025 07:25 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TDonkey
Jul 26, 2015 10:14 AM
toofly1999
Jul 25, 2015 07:09 PM
msane99
Jul 17, 2015 10:13 AM
