keeps blowing fuses
Old Jan 3, 2008 | 01:29 PM
ryanflknr's Avatar
keeps blowing fuses
I have a 90 pickup that keeps blowing the EFI fuse everytime I try to start it. I've traced the wires and everyting and I got it running yesterday and then it cut off on me because my harmonic balance messed up and broke the belt so my battery went dead then I checked and the fuse blew again. Can you guys help me out a little bit?
Old Jan 3, 2008 | 02:24 PM
TORTIS's Avatar
i am no electrician, but it sounds like a short some where. did you check for frayed wires?
Old Jan 3, 2008 | 02:38 PM
as2sb3100's Avatar
You have a 3.0 v6? My solution was to run a new wire from my battery to the fuel pump and computer. Thats what that 15 amp efi fuse powers. And then I threw a relay in the mix so that the fuel pump and computer are turned off/on with the key. The hard part is finding a power source that isn't turned off when you start the truck.
Feel free to PM me for details.
Old Jan 3, 2008 | 07:50 PM
TNRabbit's Avatar
Double check that the wires to the O2 sensore aren't burned thru over the exhaust.
puddlepirate
Jul 30, 2016 06:29 PM
4banginRunner
Nov 13, 2015 05:23 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
