PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 [266] 267
  1. Body stripe glue removing?
  2. Bought used '94 4Runner. Have questions now.
  3. Transfer case rear bearing replacement
  4. Need help Clutch Problem
  5. Dreaded CEL...Code 25
  6. Whining sound
  7. '94 4-Runner clutch woes
  8. Slip Yoke Compatibility
  9. Timing Belt/water pump write up?
  10. Bad smell/odor from the exhaust
  11. 89 FRONT power window relay where is it ??
  12. Best place to purchase leaf springs?
  13. HELP!!! '86 Automatic Transmission Acting Weird
  14. drivers side window troubles
  15. For the life of me, I can't find the inclometer wiring harness
  16. Can't figure out how to replace headlamps... feel like an idiot
  17. life after hub conversion
  18. RPMs STILL fluxuating....
  19. 95 4Runner won't start
  20. Rocker Arm adjustment ?'s 22RE
  21. Pacesetter Header for 22re
  22. 94 2wd brake fade and idling issue
  23. Cooling Hose @ back of Intake manafold!!!!
  24. 86 22rte turbo adjustments
  25. 3.0L to 3.0L swap, urgent help in Denver!!
  26. pittman arm seized
  27. Truck won't start when COLD
  28. Broken Leaf Spring $$$?
  29. Engine Knocking and engine code 13 help please
  30. everyone with a gen 2 who wants altezza tails needs to read this
  31. installing oil pressure guage, will the light stay on?
  32. 1990 toyota p/u.....clutch malfunction......any info??
  33. Can't engage 4wd: ADD = suck
  34. ? concerning timing chain
  35. Pinging Noises
  36. 1st gen clutch line - best place to get?
  37. 95 generation 2 lift
  38. Brake Lines Rusty-- ABS modulator
  39. 92 2WD 5 Speed Tranny Shifter Removal
  40. Ball Joints & Tie Rod Ends
  41. Steering Stabilizer question
  42. starter too close to exhaust on 3vze?
  43. Pictures of 22RE EFI engine!
  44. A340H exploded views...
  45. Ran, then died. 87 4Runner 22RE/5spd.
  46. Help finding 3.0 engine block coolant drains & misc ????'s
  47. parts interchangable? rear differential
  48. little response from the brakes braking
  49. Why won't it start
  50. Tranny cooler
  51. AC work legal?
  52. Just spent 117 bucks on the 4Runner
  53. Water pump brand
  54. air conditioner not working
  55. CV Joint Axle Studs..cheap tricks
  56. Truck making clunking sound, please help
  57. 2 pinion or 4 pinion differential
  58. Leaking oil in the coolant
  59. Sticky Emergency Brake
  60. battery light: I need some advice, not alternator
  61. weird creek on 1993 pickup 4x4
  62. 89 22re - Tach electronic or mechanical?
  63. Auto Transmission solenoids ?
  64. 22re died NEED HELP
  65. Towing ability of 4 cylinder engine?
  66. Overdive Light blinking when I check diagnostic
  67. HELP- 94 3.0 dies all of a sudden.When hot.
  68. 22re pinging condition...
  69. Unhooking Air Conditioner unit
  70. i got in an accident, now what?
  71. Replacing brake rotors?
  72. Add a leaf, anything I should be aware of?
  73. cv axel boot problems
  74. Ruptured brake line.
  75. Squealing at Idle
  76. front end rattle
  77. Bogs missing misfire TPS? AFM?
  78. 95 auto tranny transmission overheating and unrelated towing Q
  79. will not start!
  80. Pic of my 89 Runner
  81. Oil Pressure Sender not functioning after deep water crossing
  82. 2nd Gen. Overheat ???'s
  83. More Auto Trany Problems
  84. Loss from age/mileage
  85. Oh man......I think I've got the wrong altimeter thing for my 4Runner!
  86. 22RE issues
  87. my runner makes a funny smell at high revs
  88. Man, I can't even figure out how to get the spare wheel lowered
  89. Ughhhh!! I have my "altimeter" ready to install, but can't get the dash off!!
  90. Idler pulley replacement??
  91. Cool 22RTE websites
  92. oil leaking money pit
  93. PCV valve removal.....what do I need, a winch??
  94. Got all the parts
  95. Key/Ignition Lock Cylinder Replacement
  96. How much power do I make???
  97. How to remove the Timing Belt tensioner pulley from water pump?
  98. Slight overheat 95 4Runner
  99. torque adjusting nut size disc brake replacement specs?
  100. Can I replace the camshaft without removing the cylinder head?
  101. Igniter?
  102. #1 cylinder not firing
  103. Clacking, timing chain or valves
  104. unhooking unpluging ECU wiring harness
  105. brake lights and bulbs not working
  106. Maintenance questions for 1st Gen (Help please!!!)
  107. Why are there 4 (that's right....4!!) sets of seatbelts in my back seat?
  108. Can a complete head assembly be purchased?
  109. Hot start problems with 22RE
  110. Carbon fiber hood with scoop for 2nd gen
  111. Which camshaft for a little more power?
  112. 22RE dies on startup - need help fast!
  113. Flares on a 2door 2 gen?
  114. Am I the first with a rear window problem??
  115. Clutch pedal response
  116. Signs that block is cracked
  117. bad 3.0 5 speed tranny problem
  118. head job gone bad
  119. Power Steering Pump out
  120. battery and parking brake lights on
  121. what to do w/ a busted 2nd gen
  122. Coolant System Help Needed
  123. 95 4runner cranks but wont start ?
  124. Exhaust smokes... help!
  125. I'm not sure if I fit in here.............
  126. Can you still get the OEM decals for the 4Runner?
  127. Rear Main Seal Leaking
  128. Installing inclimeter?
  129. 4Runner Rear End Woes
  130. Can I update my instrument cluster?
  131. POLL: What 2nd gen bumper do you like more?
  132. Who wants Mods for the 3.0?
  133. Hissing from AFM & REALLY low idle when warm.
  134. 33's. 4.88 or 5.29 gears?
  135. Its baaack - 7mge VAFM swap for the 3vze!
  136. NEW Thorley 3.0 (3VZE) Headers
  137. Radiator replacement
  138. Downey 2.5" install
  139. How many miles on a FULL tank of gas?
  140. IFS steering gear leaks
  141. dashboard lights don't work
  142. No Power when engine warm (22RE)
  143. 3VZE- rough idle, stumbling, lost power...help!
  144. 89 4Runner Rear Body Panels
  145. Timing belt problems
  146. battery wire sizing
  147. Clutch master cylinder is making noise.. help please
  148. 1st gen Amsoil filter - too big?
  149. CEL error code 71..
  150. ARB rear air locker question
  151. 2 door - 2nd generation....lets see some pics
  152. 3vze VAFM help....
  153. 2nd gen 4Runner hard starting
  154. 86 4Runner fuse panel layout and rear window problems??
  155. A/C Compressor not working
  156. Help! Does anybody have a new 2nd gen Edelbrock front shock? (pn: 33992)
  157. Reminder: It's time to lube your spare tire lowering mechanism
  158. Question on 2nd gen rear shock removal
  159. 22re running rough (searched and searched)
  160. Check out my new 87 Toy
  161. Exhaust leak
  162. Headlight aim on my '95
  163. 90 4Runner rear lift and long travel front
  164. Does anybody know this dude
  165. 2nd Gen gas tank
  166. 22REt Turbo Engine ??
  167. CHECK ENGINE CODE 25 and 26 NEED HELP?
  168. 3vze alternate intake manifold
  169. Non Body Lift Raise?
  170. 3vze Top End rebuild...W/pics...slowly
  171. Can't remove bolt from lateral conrol rod!
  172. 92 Pickup Fuel Filter
  173. My 3.0 is vapor locking.
  174. Knock sensor function?
  175. Looking for performance
  176. HELP! Toyo M/T Tire fitment?
  177. CV Boots.....done!
  178. 2nd Gen LSD Diff question
  179. 'Candied' Taillights on a 2nd Gen.
  180. Gear ratio?
  181. Are there any V6 1st gen runners?
  182. 1994 4x4 4runner engine size?
  183. 3.4 swaps galore. pics of 3 swapped trucks and more.
  184. Help 86 PU not getting spark...
  185. My take on Blu's Air Silencer Removal Mod 2nd Gen.
  186. 94 IFS articulation, I want more??
  187. The Ball Joint spacer/Cruiser Coil - Longer Shock P/N thread
  188. Best Headers for the 3VZE?
  189. Adding Rear Window Defroster to 1st Gen - Practical?
  190. Just another rattle-can paint job
  191. 22re crank case pressure blowing dipstick out
  192. What springs should i get
  193. Downey suspension lift
  194. Pic of 2nd gen Clear Taillights?!
  195. Mods for the 3.0 durring a full rebuild
  196. 1st & 2nd Gen IFS differential question...
  197. 4runner hardtop removal
  198. Transfer Case Tailshaft vibration over 35MPH
  199. 2nd gen mystery electrical problem solved + write-up
  200. Sway bar Quick Release
  201. Procomp shocks and steering stabilizer
  202. anyone have/install REAR speakers on a 1st gen 4Runner?
  203. 2nd gen slider length?
  204. Procomp ES2000 Steering Stabilizer
  205. POLL: Who wants 22RE over 3VZE? Count me in!
  206. 2nd Gen 3VZE engine: R U thinking of doing timing belt/water pump? My observations
  207. Beware Of Clutch Bracket Fatigue!
  208. 92 4runner ADD Front Differential failure?
  209. My 4Runners Stats, Take A Look,
  210. 1990 2-door 4 Runner....Rare?
  211. How do i change a 2nd gen tstat
  212. removing the pilot bearing
  213. 2nd gen cargo cover?
  214. Fan Clutch help
  215. 94 with no lift?
  216. Rear grinding noise?
  217. Front Differential - Stupid ? for the night
  218. How many 3VZE miles you got???
  219. newbie here
  220. 3.0 Front differential breather
  221. 91 3VZE compression test how to?
  222. 4wd failing to engage
  223. 2nd gen brake rotor replacement??
  224. 3vze How many miles?
  225. Panhard Rod drop bracket or Adjustable Panhard Rod?
  226. 2nd gen proven engine mods ??
  227. Taurus fan Install writeup 3.0 V6
  228. '95 100K maintenance
  229. Oil Pan removal on 2nd Gen 4WD Pickup - HOW TO
  230. Procomp ES3000
  231. Speed sensor or something else?
  232. Who's added a hitch to their 2nd Gen e.g. Hidden Hitch or Drawtite
  233. How do I get rid of the 4runner rear sag with a Procomp 4" lift ?
  234. Just changed Fuel Filter....AAAAARRRGGGHHH
  235. heater blows cold & RPM bounce (2nd Gen 4Runner)
  236. Emergency Brake Woes...
  237. Fitting 33" tires on 2nd gen 4runner?
  238. Adjustable vacuum on inner fender?
  239. cargo box dimensions or plans?
  240. Downey 3" panhard drop bracket
  241. Coolant flush
  242. Attention 4cyl timing chain owners
  243. a pic of my 4 Runner
  244. Wolf Cargo cover
  245. Rear Poly Sway bar bushings
  246. Brand of Exhaust
  247. Electric fan
  248. few new pictures on project crusty
  249. giving head...
  250. Wow! what just happened with my heater core?
