Cooling Hose @ back of Intake manafold!!!!
Old Aug 12, 2005 | 07:20 AM
On a 3.0 out of a 91' runner. what is the best way to get this hose off? It is leaking, do i have to pull the whole air intake off??? I don't think that I hav enought room to get to the clamp!!
any ideas??
thanks guys
boo :alien:
Old Aug 13, 2005 | 10:52 AM
94x4's Avatar
Guest
I'm sorry, you want to remove the what?
Old Aug 13, 2005 | 06:51 PM
ChickenLover's Avatar
I would recommend taking the plenum off. That way you can knock out some much needed maintenance while you are at it (cleaning t-body, intake, and plenum as well as replacing the pcv valve). If you have leaky valve covers that would be a great time to replace 'em too.
Removing the plenum is not as bad as it looks. take off the egr and reed vavles as well as the 7th injector's fuel line. Unbolt the plenum and just flip it up and out of the way. There is no need to take off all of the vacuum lines. Once you've done it once or twice it becomes a non-issue.
steve miller
Oct 10, 2015 01:40 AM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
elwood73
Jul 5, 2015 07:07 AM
