Need help Clutch Problem
Old Aug 23, 2005 | 12:12 PM
jerbear's Avatar
Hello all
Found a donor engine for my 1991 4x4 xcab with a 5speed 3.0 V-6. Since I am recovering from surgery, my brother and my bud have been putting it in the last two days. Well it is in and running well. The problem is that I have no clutch pedal. They have bled the slave cylinder and there is still no resistance on the pedal and it goes to the floor and stays there. What did we screw up? Please help, I still have the guys here for a few more hours.
Old Aug 23, 2005 | 01:05 PM
jerbear's Avatar
BUMP Please help if you can
Old Aug 23, 2005 | 02:34 PM
eric-the-red's Avatar
Look underneath and check if the slave cylinder rod is actually getting pushed out. If not then your slave or master is shot.
If the rod's moving out then something inside the clutch housing isn't connected, and that isn't good news.
Old Aug 23, 2005 | 02:39 PM
jerbear's Avatar
My brother says he can see the rod move a little, sorry I can't be more precise. We are going to work on other stuff for a while and then come back at it later. So any suggestions are greatly appreciated. We are also getting a 1 man bleeder so he can pull the fluid through, if that makes sense.
Thanks
Old Aug 23, 2005 | 04:19 PM
Sorry, that's about the limit of my suggestions. I don't know how much the rod should move. I drive an '01 4Runner with an auto tranny, so I don't have something to look at and see.
At least this will bump your post back to the top.
Old Aug 23, 2005 | 04:44 PM
jerbear's Avatar
Bump C'mon please help. We are done for the night and we will be back at it in the morning.
Old Aug 24, 2005 | 11:15 AM
94x4's Avatar
Guest
Try reverse bleeding it as you've mentioned ("...pull the fluid through...") to get some pressure into the cylinders and give it a go then.
Old Aug 24, 2005 | 11:18 AM
jimbo74's Avatar
you said you bled the slave, but have you done anything to the mc? it sounds like the mc isnt doing its job properly
Old Aug 29, 2005 | 06:41 PM
bryan's Avatar
I am having the same prob. With the pedal on the floor you can watch the slave cylinder go out and then slowly go back in. I have changed the slave cylinder and bleed the sys, a few times. I think it's the MC, my question is should I go with Toyota or aftermarket? Any help / experince would be great. Thanks Bryan
Old Sep 11, 2005 | 07:50 AM
bryan's Avatar
I ened up haveing to change my master cylinder and the reverse bleed it and it work fine now.
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
the1998sr5
Jul 16, 2015 06:20 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
