CHECK ENGINE CODE 25 and 26 NEED HELP?
Old Feb 16, 2005 | 11:06 AM
corvettelvr73's Avatar
My check engine light has been ramdomly going on and off for the past couple months. The codes are Running lean indicator and running rich. I have 120,000 miles and i changed the oxygen sensor with a OEM Toyota sensor at 97,000 miles due to the same codes. Now what could be the problem and how can I go about checking other sensors? Does anyone know a link to a factory service manual? My haynes manual gives about 6 different possible causes but I not sure on how to go about checking them. I am very mechanically inclined however these computerized things drive me crazy. LOL. Thanks in advance.
Old Feb 16, 2005 | 11:42 AM
NathanBERG's Avatar
Have you pulled your battery cable to clear the codes??? Make sure you have cleared them so you don't look at an old code as this can be confusing.
the oxygen sensor and the Mass Air Flow Sensor (MAF) are common suspect items.
Old Feb 16, 2005 | 11:57 AM
yes i have pulled the efi fuse too many times and the light goeas out for about 50 miles
Old Feb 17, 2005 | 07:52 PM
bump!
Old Feb 17, 2005 | 08:05 PM
ATP4984's Avatar
Take it to a shop and have them check the compression on all of your cylinders. Mine needed a valve adjustment when I had the same problem.
Old Sep 6, 2005 | 04:33 AM
callmej75's Avatar
haha....i just got them codes and found out my head gasket was going....its the reason I'm not driving it right now.
Old Sep 27, 2005 | 09:03 AM
NathanBERG's Avatar
My codes 25 and 26 are GONE FOR GOOD! Bad o2 sensor.
Why did that light drive me nuts???!!
Old Sep 27, 2005 | 02:16 PM
NathanBERG's Avatar
Did I say for good? I ment, good for a day lol Darn thing is never going to go away!
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
