- Camshaft bolt removal for a timing chain install
- recall
- Pre face lift conversion.
- Need Help 92 22re cough/bogging while driving
- 2.8 diesel power steering on a 22r?
- truck wont start
- 22re not turning over!?!?!?!
- Quick Slave Cylinder Help
- 89 Toyota Truck 4x4 V6 - Oil Leak
- code 14 died while driving on highway
- Cold Air Intake Kit
- 88 4Runner to 1kd-ftv d-4d swap
- anyone try this dash pad cover
- 1st Gen 4Runners: Low Fuel Light
- what sensor is this?
- break in oil change?!
- Air Tank Bumper
- 87 4rnr A340H Bizarre behavior
- Im thinking trany is shot?
- 1987 22re Code 11 help
- 88 22re to 22r with weber swao
- Those final parts, well
- How do I bleed the brakes?
- 89 22RE Belt info?? part number??
- transmisson info needed
- will 1989 3.0 swap to a 93 truck ?
- Start up issues when colds
- Pickup spare tire hangers
- 1992 Toyota Pickup - Failed Emissions
- 22R Head
- More EVAP questions
- 3VZE oil filter seal keeps blowing
- 91 22-RE advice.
- 86 pickup 4x4 grille emblem color
- Engine assembly tips?
- Dashboard additional buttons?
- 88 3vz into 93 4runner
- Starting Issues -94 4Runner
- Frame Swap: 1986 Toyota 4Runner (Pictures!)
- Muddy fuel filter but clean gas?
- 40/60 split seat question
- 2 stage thermostat ?
- Steering wheel hub adapter?
- 22re temp gauge sensor?
- Front hub question.
- Rear tire carrier suggestions
- Help with vacuum questions.....
- 89 1st Gen V6 parts truck for a 92 4Runner
- Exhaust System Replacement
- O/D Warning Light
- Replacing Piston Rings on a 3vze
- replaced clutch system still doesn't work
- waterproof seat covers and pull the top off or get the ac fixed?
- Runner shuts off while driving
- High Beam Wire, where to tap into?
- Head gasket blown - Should I keep the 4Runner or fix it
- engine rebuild starting issues
- Power/hot wire from AC compressor...?
- I want to put a holley on my 1987 22r?
- cracked head? 22re
- Throttle Body Won't Close
- Will this transfer case work with this transmission?
- 87 Sr5 22re Starting problem, idle problem.
- No Clutch Pedal Pressure
- 22re Strong gas smell
- Manual shift Knob
- undecided - standard or automatic trans
- Break in oil and procedure
- My truck (& my back) took a beating today....
- A/C Compressor wire cut! help! '89 pickup 3.0
- Soaked drivers side
- 3.0 to 22re swap
- Rear window interchangeability?
- Grille Guard, push bar, bull bar for my 94
- 22re no start
- 87 4runner,center mount ifs diff,mid travel or long travel?
- New member with '92 Truck
- Leaf spring help!!
- Fuel pump shoot off a service engine light?
- 94 4runner front left hub noise
- 87 4Runner gasket part # HELP!
- What causes rear end sag?
- Low Compression, 87 Pickup Won't Start, Advice
- 86 Pickup 22R 4x4 - ongoing project.
- Zuk Mod (pictures)
- 22re valve adjustment guestion
- 88 Pickup 88 4runner A/C swap ?? Help
- What is this rear brake line??
- lower radiator hose help
- 89 Toyota Pickup front passenger brake locking up
- soft top for 87 4runner
- 94 toyota pickup, led f&r turn signals don't work, hazards do
- 22re valve tapping noise
- Installing new a/c system
- 94 3vze front end rebuild & rear susp. advice
- Toyota pickup 22re help
- gear indacator
- Exhaust frustration
- Hub Change Out
- ifs factory 4:88 swap ?s
- 92 RE22 tranny wiring harness
- lets talk about tune ups
- 1986 22re rebuilt head
- how are you attaching your spare to your roll bar
- Torsion bar HELP!
- Are chassis rail sleeves/stiffener/backin plate require for rear bar install
- Coolant disappearing?
- Can't find my tranny type anywhere
- Mass Air Flow Sensor/Meter Destruction
- Sway bar bushings
- 22RE w/180k miles -- new catalytic converter time?
- Alternator or another gremline... 3vze
- a/c compressor
- 22re engine transmission not bolting together
- Swapping 94 Pickup grill with a Tacoma grill...
- Starting problems!
- Clutch issues, engaging while clutch is depressed.
- Transmission/T-Case lunched, stuck in MS
- Suspension lift for IFS?
- Dash Gages wont work?
- fuel injector rebuild query..aharharhar
- Sway bar 23mm or 27mm
- 1993 toyota half throttle it falls on it face
- would u fix or let go?
- Hard to start when ambient temperature rises
- Which FSM for '89
- Strange steering problem w/ 2nd gen Runner in 4x4
- Another exhaust noise thread
- cold start knock
- 89 Toyota 3vze Throttle Body issues
- Speed Sensor rebuilt write-up
- 3vze cat question?
- Hydrolocked 1990 22re, Guidance please
- Where to get new exhaust?
- Tranny noise
- 4x4...it kinda works?
- 86 dome light ??
- 94 4x4 frame
- Lexus IS300 LSD in '88 Toy Truck Rr Axle
- Bad TPS?
- Loss of power uphill (troubleshooting help)
- got new doors. how can i make half doors out of old ones?
- Time to Rebuild My Leaky Power Steering Pump
- Lock Knob Holder Install?
- Won't start, high pitched sound, 95 4runner
- Won't start high pitched noise 954runner
- 1987 and Computer
- New to forum - lugnut question
- Build Questions: 22R-TE
- gasket at fuel line ??
- o ring mistery ??
- Scanner???
- 94' 22re 2wd exhaust leak.... remove pipe how?
- crankshaft to a/t mounting question
- 3vze "flex fuel" idea....does this seem plausible?
- Locktite? on t-case/tranny bolts
- TPS or Idle Air Control Valve?
- smog results
- bobbed bed leaf spring swap ?
- valve shim help
- Whats up? Do I need a sway bar?
- 86 4runner transfer case
- '92 sr5 3.0efi v6 engine tick, and check engine light
- any ideas of what caused this fire?
- what does this wire go to ?
- 95 cummins build
- 92 pick up with squeaking from rear end
- Front Wheel Bearing Replacement
- Manual Transmission Model No.
- Igntion problems
- Putney 22 re performance
- ect power switch, mind of it's own, just want it fixed
- What muffler do you 3VZE guys run???
- What else affects the TPS?
- Please Help Bad Idle
- 92 22re hesitation
- 1987 HunterRunner's build up thread
- Downey headers and build plans
- Tires/suspension/whatever else? for 94 truck
- Horrible mileage (22R)
- 88 22re keeps breaking flywheel bolts????
- Just got my first 'Yota
- 1991 4runner v6 standard transmission wont go into gear
- Rough at Start, Manuals, and Gas Mileage Questions
- 90 4runner clutch issues
- bogging and rough idle?
- weird air box noise
- Hard shifting on decel in 90 4x4 automatic????
- 22R Power Steering Idler pulley tension bolt
- 22RE Coolant Lines/Hoses
- OMG, IT'S ALIVE!! (Finally)
- '92 sr5 pickup. All stock. Where to start?
- Power Steering Pump
- 22RE oil leak from passanger side oil pump bolt
- how do i add power steering to my yota!
- temperature switch help
- rough start/rough running!
- Is My Speedometer Broken or Something Else?
- Idle Speed Screw O-Ring Size
- Removing engine on 1987 Toyota pickup
- bypass AUTO lockout????
- windshield repair, what to use on rust?
- Bed rail caps for an 86
- 92 22RE TPS Code 41 and 51
- W56 whine in 5th Gear
- 2nd gen 4runnner not engaging at all
- have too kick down idle
- Dashmat Color Decision??
- cyl 2 and 3- 0 compression
- High idle only when motor is cool
- What is the part number of this?
- Click in front end while in 4wd
- 88 4runner coolant temp gauge
- Strange slurp sound after a rev
- 22re will not idle after replacing head gasket
- My list of engine gremlins
- Help the new guy: 94 4Runner 3.0-issues
- aisin carb vs 38 weber
- Is it possible to just replace the voltage regulator?
- Factory holes on backside of rocker panel 1994 4Runner
- Assist me in determining what to do about my 4runner going forward
- ZUK Coil Mod .....an email received
- 3vze oil pan bolts
- Help - Marlin Crawler W56-C HD transmission problems
- 1st gen. 4runner rear window question
- new member from Idaho
- Strange overheating situation
- testing o2 sensor... quick question...
- clutch pedal problem
- Is this a blown head gasket?
- Timing weirdness
- Bringing my first vehicle back to life..
- grinding noise on front end of my 86
- Lowering cold idle rpm
- Correct belt location on pully?
- Hard to start after fuel filter change...and worse mpg.....
- Reman 3vze getting too hot?
- truck wont go into gear after bleeding
- First run. Maybe went a little too big :(
- 3vze rough idle and bad 02 sensors
- Fuel vent Hoses 93 3.0
- Yes,,,,another 3.0 power question(s)...
- Are my hubs not disengaging?
- Code 25 "Lean" problem.... need serious help!
- 3vze terrible cold idle, no power
- stalling when braking
- Locker question due to clicking free wheel hubs.
- name that clunk!
- 22R TE what could it be? Rough idle - power lacking
- Driveline Vibes...
