Loss of power uphill (troubleshooting help)
Old Mar 11, 2012 | 07:39 PM
nouseforaname1246's Avatar
Ok so I have a 93 4runner with a 3vz-E(v6) engine. automatic. 4wd
A few weeks ago it started having trouble going uphill. Im talking it wont go over 15-30 mph on anything steeper than a few 5deg incline. It'll do this then suddenly full power will come back then a few seconds later it'll lose power again. pushing down on the accelerator does nothing when its doing this. no CEL.
Ive been trying to troubleshoot this for a few weekends now. I pulled codes and came back with nothing. So I downloaded the FSM and went through it looking for ideas.
so far I've checked the TPS, timing, fuel pump, fuel pressure regulator, distributor, coil, wires, plugs, EGR and i even tried a little voodoo ritual involving throwing chicken bones at it. still no luck.
Any of you had a similar experience or have any idea what else i should check?
Thanks in advance.
Old Mar 11, 2012 | 08:43 PM
vital22re's Avatar
totally a bro
Well it sounds a little like electrical. Did the transmission kick down? to a lower gear? what does the transmission do when this is happening?
Old Mar 12, 2012 | 07:23 PM
93liftedyoda's Avatar
sounds like a tranny problem
Old Apr 19, 2024 | 04:09 AM
Pams2ndgen's Avatar
Same thing happening
Thanks in advance.
did you ever figure out what this issue was.. mine is doing the exact crap.. wasnt the FI preaaurw damper either.. smh
zerohedspace
Dec 25, 2017 04:53 AM
hotdamn
Oct 16, 2012 12:42 AM
sarix
Nov 30, 2010 08:15 PM
Craigus
Dec 5, 2007 07:20 PM
rusty
Feb 11, 2005 02:21 PM
