sudden power loss
Old Feb 10, 2005 | 08:21 AM
rusty's Avatar
sudden power loss
Driving the other day and suddenly there was no power for a split second then the engine kicked back in again. I am wondering whether the coil pack is getting towards the end of it's life. I don't want to start changing bits unless it is necessary. It has done it about 10-12 times now, at random intervals.
Plugs are good (gaps are ok) it's not missing, distributor & rotor arm are ok, just a sudden complete loss of power
Any input would be appreciated
Thanks
Old Feb 10, 2005 | 06:51 PM
Fuel delivery problem maybe?? Do you still have electrical(ie.dash lights and guages) when it happens?
Old Feb 11, 2005 | 02:21 PM
rusty's Avatar
Yes all the normal stuff still works. I have had this happen when I am running on Petrol or LPG, so therefore I can only assume it is an electrical fault starting at the coil as there is no intermittent miss firing
Sleaker
Aug 26, 2020 06:03 AM
JaredL
Mar 28, 2016 09:08 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
gmonnie123
Jul 26, 2015 02:44 PM
