Start up issues when colds
Old Mar 20, 2012 | 09:01 AM
02 polish ss's Avatar
i have a 1991 toyota pickup 3vze that has start up issues the colder it is the longer i have to crank to start it, started happening after the head gaskets were done, prior to that the truck would start up first try, i did a full tune up, once the truck starts runs great, and once it starts once it start right up untill after it sits for a while again please give me some input thanks
Old Mar 20, 2012 | 11:35 AM
Team420's Avatar
The 2 things that I would check 1st would be:
1) Compression test- low compression will cause hard starts when cold
2) Cold start injector- its there for a reason, and if not working properly,will cause cold starts to take a lil longer.
Old Mar 20, 2012 | 01:38 PM
BMcEL's Avatar
I'd start by testing the cold start injector and cold start time switch.
A little searching goes a long way...this is a fairly common issue.
Old Mar 20, 2012 | 05:49 PM
howdo i check the cold start injector or time switch i kno i replaced the injector once before nvr really checked if it worked though, do i just pull it out when the truck is cold n see if it squirts fuel??
Old Mar 20, 2012 | 05:53 PM
BMcEL's Avatar
Click the links in my last post.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
