replaced clutch system still doesn't work
Old Mar 18, 2012 | 06:38 AM
thatguy88yota's Avatar
Exclamation replaced clutch system still doesn't work
So replaced the slave cylinder,master cylinder,clutch,pressure plate. and bled the system. and still my clutch pedal goes to the floor and i try to put it in first and it doesn't go into gear, obviously because the clutch is not engaging.
what are some things that maybe i should have done that would have been normal practice, like adjustments and or standard practices?
Can the lever on the tranny be messed up?
can i adjust the clutch pedal too far?
some things that might help: the lever by the tranny that the slave cylinder piston makes contact with still moves. and also when the truck is off i can still go through the gears.
Old Mar 18, 2012 | 06:56 AM
Team420's Avatar
A lil more info could be helpful Year model, engine etc.... You will always be able to go thru the gears when truck isnt running.... So... Does the pedal go to the floor easily, and stay there? Is there any pressure in the pedal, or it moves freely? If it moves freely, and the pedal stays at the floor, u need to bleed that bad boy more. Otherwise... Have you checked the clutch pedal bracket? I had mine break on my p/u a few years back and it wouldnt let me go into gear. I ended up just welding it back together in the truck....
Old Mar 18, 2012 | 08:11 AM
sorry bout that. it is a 1990 3vze motor with a standard transmission, hydraulic clutch.. yes it goes to the floor but comes back up when i let go. just has no pressure when i press down. see i thought bracket too, but why would the lever on the tranny still move i will check out the brackets though to!
Old Mar 18, 2012 | 08:12 AM
and is there any way to rule out the tranny being broken?
naward1996
Apr 23, 2018 05:23 PM
gog1968
Jun 22, 2015 05:55 AM
shadowbirdie
Jun 18, 2015 06:38 PM
