- Front Suspension
- 2nd gen stock 4runner rear bumper
- new expensive paperweights
- 22re ISSUES
- SO...... it's all ripped out! Advice??????
- 94 3.0 still plagued with Head Gasket probs.
- I swear, people just cannot drive!!!
- 22RE Crankshaft Bolt removal
- Speedometer/odometer/sensor problems
- gear and torque
- Coolant leak/advice on upper intake plenum removal
- 3.4 help.
- CSF Radiator Installed-Pics
- dual tcase
- heli coil + 22re
- intake leak on throttle body
- 5spd problems
- tundra brakes on a 2nd gen 4runner?
- Won't crank at rebuild
- 22RE reinstall
- 90 o2 sensor plug location
- 91 4Runner question on engine swap or no?
- Reasons for power steering???
- wont shift into OD till warmed up?
- Opinions about paint job price 94 Toyota truck
- to change or not to change tranny fluid?
- Check Engine After New Axle ? What >?
- O2sensor question
- Help get on accessory belts!!
- swapping 90 22re into 87 4 runner
- cruiser coil, bj spacer?s
- BJ Spacers and Lift Spindle?
- 3.0 Won't warm up
- 22re troubles
- Solid or Crush pinion spacer?
- Help! one foot on the brake and the other on the gas
- My '92 Runner
- Will 3.0 Downey Headers fit both 1st + 2nd gen
- legnth if 86 toyota 4wf pickup bumper
- 22RE Plug Gap ?
- Bouncing tach, power loss, and blown "guages" fuse
- Trying to decide on suspension and others
- New guy with a 2nd Gen
- noob 4Runner question
- starter problem
- 32x11.5 on 8" rims
- where can i find a slider latch besides the dealer
- well boys...this is goodbye :(
- Truck died all of a sudden and i have no idea why
- weird noise!
- clutch/tranny/ shifting questions.
- hot engine
- Slooow warm up.
- 3VZE Knock Sensor questions
- Lower Front Bumper Valance Paint Color Code?
- Electrical question for the guroos!
- Too high cold start idle
- '90 22R PU leaking oil
- 88 4runner part it out??
- Chain Guide Kit Prices?
- 1991 v6 Leaking Oil
- radio only works when headlights are on
- Another 3vze (just a story with a plan)
- whats the most painless engine swap for 1993 22re 5 speed
- Diff Help
- Front Brakes No Pressure!
- New truck
- Swapping a 3.4 into my 94 runner
- LED's for 2nd Gen
- Another one 1989 4runner
- Valve Rocker slightly off Help!
- 1991 x/cab Bed
- anyone running 4.88 gears with 31 inch tires?
- 37 mtrs on.
- 86 runner trans problems
- Noob Gear Oil Question.
- Trouble finding radio mounting brackets.
- over pressurized radiator
- HELP Newbie
- fuel tank sending unit?
- 22re bad knock after head gasket
- temp gauge
- rattling sound, driveshaft slop
- grease and lube
- Clutch bracket prices
- Spun a rod?
- No spark after setting couple weeks
- LC Engineer Cold Air Intake for 22 RE 88
- ADD Side Gear Shaft Excessive Play
- throttle screw stop thinging - 22RE
- Coolant sound after rad change
- Extremely annoying rattle/vibration in dash
- Prob with '91 4x4
- photos. wheeling in Wa.
- People That Have Done AFM Swap, Question ?.
- 1st gen cup holders?
- 4Runner won't stay running
- back firing problem
- 1989 Engine Knock
- 22re aftermarket heads?
- Toyota Surf gen 2 Clinometer
- Quick Question
- 86 4runner Carburetor problem?
- Neighborhood fun... Stock 2nd gen say what? (pic heavy)
- Distributer timing and code reader help
- clutch peddle grabbing inconsistantly
- Aussie locker for V6?
- new head or fix old one.
- Need help removing driver side axle
- clutch slipping? speed/RPM ratio?
- Another MTF question.
- drill and tap questions..
- Name that tick and/or knock!
- Fuel filter location
- Please help with brake problem.
- new to this forum
- for sale: 1990 2-door 4runner sr5
- clutch replacement
- uh oh 3.0 help bad week
- Help with torsion bars? (pics)
- Gauge Cluster Help?
- Fishing rod rack for inside.
- Noise in new rebuilt rear diff? break in noise? HELP!!!
- Year Differences in distributors?
- 93 4runner rear window removal problem
- Starter solenoid contact fix
- Will a seat from '92 deluxe PU fit in a '90 standard PU?
- How much MTF is enough?
- Will a 4 runner seats fit a toyota pickup 4wd ?
- Blower motor electrical
- Wilderness roof rack
- idler pulley #1
- I want an aftermarket air intake for 1990 22RE
- Code 14 & shifting into 5th is tight
- Help identify rear carrier
- need help with rear axles leak
- Help...serious issues with 87 4wd truck!
- need help with electric antenna
- 4runner balance fog lights !!!!!!!
- 95 4runner sequoia special edition
- mercury villager electric fan swap
- Serious problems with the 3.slow!
- Help me diagnose 22RE engine whistle (with video)
- 1986 clutch pedal problem
- 86 Runner ProblemS
- Trail Gear creeper breather question
- Downey cam info
- rear window issue on 1st gen runner
- slider rust
- Lean exhaust, rear window, and sunroof issues???
- 93 4Runner highway RPM range and vibrations
- fuel leak and $ questions vs knowledge
- Fan bracket fixed, now code 24
- 22re Idle help (1993 pickup)
- O2sensor question
- The paper clip trick
- Slotted roters worth the money?
- whats behind a 22re cylinder head?
- Manual Swap Electrical Questions
- 3.0L help
- oil in vac hoses
- Can you put a V6 Radiator in a 4Cly ??
- Advice for 87 pickup that's been sitting for 7 years
- Am I crazy? Possible 86 4runner resto
- Aftermarket Torsion Bars ???
- Flag Flown From Operation Iraqi Freedom
- 95 4Runner AT swap to 5 speed
- 3vze swap gone awry
- Intake Help
- Another Eb 261C/268T thread
- How do I get the PCV valve out
- Help! What did I do wrong? (long block swap)
- does the...
- Dash brake light?
- 3.0L doing weird things?
- Drum roll please!!! new addition to my toyota family
- knocking bottom end
- Slow radiator leak, almost toast !!!
- 22r engine pulling woes
- clutch install Q?s
- winding/ whirring/buzzing noise when clutch is let up, goes away when clutch pressed
- first time O/R in the yota
- Leaf in Rear? And lift ?'s
- New harmonic balancer wobbles
- 88 toyota electrical issue
- Where to buy Aisin Hub rebuild kits?
- What Oil to use for Lubricating Valves?
- 88 4runner steering cranked clunk noise
- 88 4runner 4wd steering seizup please help!
- Who's running TG Birfs or Marfields?
- Head gasket or something else?
- 86 Toyota 22REC firing on 3 cylinders?
- 3vze noise
- Brake Light Won't Go Out
- rebuilt my 3vze and it has no power
- Funky idle on on warmup.
- hub is locked in free position
- 1kzte 3.0l diesel oil pressure
- 86 22re rebuild dilemma
- 90 blower motor
- adjusting valves
- New HG 22RE Still Blowing White Smoke
- toyota 4runner 1993 2 doors
- Quick question about timing
- why does the orientation of the driveshaft yoke on the pinion flange matter?
- Passing Emissions
- Please Does anyone know where this vacuum goes to? 22re
- Hitch inserts For sale
- fault code help needed (code 12)
- Truck gets cold on long drives in cold weather?
- Just some random pics I found....
- still tapping noise after timing chain replacement
- Rusty Coolant/Coolant FAQ
- Anyone running 32s with 4.88s?
- Voltage at A/C VSV plug
- Have to hold it in 5th gear
- my new bumper.
- Auto missing 3rd gear only?
- odd noises when steering...
- need filler fuel hose, (for 2wd box) ..anyone?
- Annoying rattle under acceleration
- water in oil
- 22re coolant tube to intake gasket
- No smoke, changed oil now smokes blue.
- still overcooling! 22re
- 4Runner 3VZE Engine Build Pics***
- 2nd Gen 4Runner vs. Current Baby Seat Standards..
- problem with 4x4 components..
- Erratic Transmission and Idle
- Just Finished: OME 2" springs and BJ Spacers
- Help with trouble shooting codes
- deleted balance shafts?
- Question On Valve Adjusment
- 3VZE Wiring Harness Difference: 88-95
- water bypass tube???
- Heater blower issues
- New here, well somewhat.
- Head on before timing?
- Fuel from Charcoal Canister
- 4Runner Tailgate Question
- Where can I buy new bed bolts?
- quick question: exhaust man. leak
- Speedo off 10MPH
- 3.0 Timing Fluctuation
- Did i buy the wrong gears
- question about 4runner and pickup parts campatability
- Where is the coolant going?
- New Fuel Pump and Cap=Squirting Charc Canister!
- no 4th gear whant to fix it!!
- ngk iridium ix plugs
