Coolant sound after rad change
Old Oct 4, 2009 | 04:54 AM
skinnadoor's Avatar
Probly nothing, but i got a new rad installed and during the first start in the morning when the idle is high, you can noticably hear coolant dripping like slow tap water from somewhere inside the middle of the dash.
Think this could just be an air-lock from the rad change ?
Old Oct 5, 2009 | 09:19 AM
machine23's Avatar
did you allow your heater core to get full flow of water when you were adding coolant in? as in having the control valve all the way to the right for hot?
push that lever for the heater temp all the way to the right, let your engine run for a little while. like 2 minutes. then shut it off, and if your radiator is lower on coolant then i would guess that was your problem. just some air in the heater core
Old Oct 5, 2009 | 11:13 AM
Matt16's Avatar
do this while parked on a hill facing uphill with the rad cap open. its called "burping" the rad.
Old Oct 7, 2009 | 11:15 PM
skinnadoor's Avatar
Thanks alot for that tip guys, will burp the old girl in the AM.
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
the1998sr5
Jul 16, 2015 06:20 AM
dinks07
Jul 15, 2015 05:34 PM
ryerye13
Jul 14, 2015 08:27 AM
