LED's for 2nd Gen
Old Oct 4, 2009 | 08:14 PM
Hilux808's Avatar
LED's for 2nd Gen
I've tried searching but haven't been able to find it. I was wondering if anyone could tell me what kind of led lights can be used in a 2nd generation 4Runner interior/cluster. I can't find the exact amount or type for the instrument cluster. I'm guessing either #168 or #74? Anybody know how many lumens would be good when choosing leds for the cluster?
I would like change everything to an led. I think the center console switches for the rear window uses the neo-type led? Anyone know what type of neo...3,4,5? I think the ash tray and the climate control panel uses a #74?
I've been searching on superbrightleds.com and there's so much to choose from
Any help or links would be appreciated.
Old Oct 4, 2009 | 08:22 PM
MaK92-4RnR's Avatar
www.Superbrightleds.com
They even have a guide that tells you which bulbs go where which is here:
http://www.sylvania.com/ConsumerProd...lacementGuide/
Just punch in your make, model and year and it'll come up with everything you'll need.
Old Oct 4, 2009 | 08:27 PM
Hilux808's Avatar
Yeah, tried that. I noticed the light they list for the "back up" is wrong, my 91' 4Runner uses a #921. I noticed that they also list #194 for the instrument panel. I was hoping that someone with a 2nd gen who has done this mod can verify this for me. Also for the center console switches and A/C panel and ash tray light. I'll keep searching too.
Old Oct 4, 2009 | 08:30 PM
MaK92-4RnR's Avatar
I believe #194 is correct... now im not too sure. I've been looking into this mod ( blue LEDs) for all of my interior lights. I know theres quite a few guides out there. i know 194 and 74s are popular for the dash lights.
Old Oct 4, 2009 | 08:32 PM
Hilux808's Avatar
yeah, if we could just figure this out before ordering. I still can't figure out how many lumens to choose. I don't want to get a led that's not as bright as the bulb i'm replacing.
Old Oct 4, 2009 | 08:38 PM
MaK92-4RnR's Avatar
im pretty sure any LED you put in there will be brighter than stock... but hopefully someone wiill chime in. I'd like to know how many bulbs are needed... a part list would be PERFECT. Heres a good write up for 2nd gens. but it doesn't give a parts list.\
https://www.yotatech.com/~corey/tech...lo/l33t35t.htm
Old Oct 5, 2009 | 08:07 PM
idanity's Avatar
i would be concerned with getting pulled over, or directing them correctly...
otherwise, its a great idea.
i hope they are more widely availible.
or lasers...or nightvision
Old Oct 5, 2009 | 09:33 PM
Hilux808's Avatar
I'm mainly wanting leds (l.e.d.) for interior lighting. I know of all the exterior lights I would need and leds for that are really expensive. That and some are not bright enough, like for my reverse lamps which use #921. I couldn't find a #921 led that gives off the same amount of lumens as a#921 incandescent bulb (around 260 lumens). I'm getting a set of PIAA #921 Xtreme Whites for that, hopefully it will make things brighter in the back when I throw it into reverse.
My search is starting to narrow on what I need for the interior, it's looking like #194 or #168 (I think these are identical) for the guage cluster, #74 for the ash tray and A/C panel and Neo Wedge type (NEO5) for the various switches in the center console and dash. I'm assuming the cigarette lighter takes a #74 but I haven't verified that yet. Also a 31mm Festoon for the center dome light and a 37mm for the trunk dome light. I have the 22RE so my 4Runner didn't come with the 2 lamps mounted under the rear view mirror as the V6 models have.
If anyone knows more about what leds can be used in a 2nd gen please share the wealth.
Old Oct 5, 2009 | 09:48 PM
RobD's Avatar
I did the swap, but only changed out the main ones in the gauges and the one in the heater panel.
If memory serves, there are 4 #194s and 2 #74s in the gauges and 1 #74 in the heater panel. Now, if you want to change your idiot lights, you're looking at a bunch more #74s. My suggestion is to pull your gauges and count exactly how many you need and order up a couple extra while you're at it.
Pick the ones that offer 360 illumination. If you go with just a single element LED, you're going to get nothing but bright spots and poor coverage. I used the 5 element ones, but would probably order the 360 with high power SMD LEDs.
http://www.superbrightleds.com/mini-wedge.html
Old Oct 5, 2009 | 10:13 PM
Hilux808's Avatar
Thanks RobD, Hopefully I can change everything out and eventually do a write-up on it. It would be nice if I could find a gauge cluster in a junkyard to play with before I rip mine out. I use my truck everyday so i would like to just order everything at once.
Do you remember what lumens for what leds you ordered for your truck?
Old Jan 14, 2010 | 07:08 PM
calipatient's Avatar
the cig lighter, glovebox, climate control, and steering column bulbs are all #74 but as RobD said, use the multi direction for the best coverage.
I replaced all of mine with red 74-xHP3 from superbrightleds.com
EXCEPT the climate control i used clear but red would have looked good too.
I also changed out my dome lights front and rear with red festoon bulbs.
im still wondering on how to change the rear view mirror lights... i imagine they are festoon as well. anyone know about these? and how to get to the bulbs?
suppra87
Jul 15, 2021 05:15 PM
RyanJ989
11
Apr 7, 2021 09:41 AM
runnermedic
13
Sep 21, 2015 05:20 PM
dropzone
Sep 13, 2015 11:18 AM
reallynotamechanic
Sep 11, 2015 11:52 AM
