89 22re trying to pass smog
Old Jan 12, 2010 | 09:34 PM
Tokez420's Avatar
in california trying to pass smog. before smog check peformed oil change, plugs, cap and rotor, pcv valve, wires.
smog test results
15mph
HC max 135
HC meas 188
CO max 0.87
CO meas 0.27
NO max 1058
NO meas 476
25mph
HC max 115
HC meas 115
CO max 1.08
CO meas 0.21
NO max 918
NO meas 470
last time it passed ok. now since then the cat got stolen! i know for a fact my dad installed the cheapest one there like $100 i think. so should i just intall a CA one from like kragen or autozone? is the universal cat thats on there preventing me from passing? oh and the engine was rebuilt maybe like 20,000 miles ago.
Old Jan 12, 2010 | 10:21 PM
Erik Beeman's Avatar
Throw some alcohol in there
Old Jan 14, 2010 | 05:38 PM
abecedarian's Avatar
Can't buy them from the local auto parts stores anymore. They have to be installed by a licensed installer, have to meet basic OEM quality standards, etc.
EB may be on to something- tossing some alcohol in may help.
Now, it's only your HC's failing at lower RPM's so it's probably not the converter. Considering the CO is relatively constant, dropping at higher RPM's, supports that. Your NOx readings are well below fail, even at low RPM's, and thus also support proper converter operation.
Verify your valves are adjusted properly and to spec, and if you can, try advancing the timing a bit. That will raise the NOx some, but should also lower HC's.
Old Jan 14, 2010 | 06:46 PM
rangerruck's Avatar
it is proly gunked up, do a couple of seafoam treatments through the engine, WHILE IT IS HOT, and see if that doesn't fix up the prob... if not, then time for a new CAT.
Old Jan 14, 2010 | 07:20 PM
peow130's Avatar
Be like all the carbed guys, spray an entire can of carb cleaner into the throttle body while it's running..
Then run the #$%# out of it before you get there.
jasonty
41
Dec 23, 2018 01:00 PM
shisha1999
Sep 21, 2015 08:22 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
accuracy
Aug 4, 2015 08:05 PM
timmJ
Jul 7, 2015 02:01 PM
