PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Electric fan istall on 1990 4runner
  2. Test fuel pressure 91 3.0 4runner
  3. Flamethrower injector issue
  4. coax line from O2 sensor
  5. Is this normal: gap in body mount location
  6. Help with passenger side power window
  7. Another Wisconsin SR5 Coming Back From The Dead
  8. 93 Xtra Cab: rear drive shaft options?
  9. 3vze rebuild.
  10. 3vze rebuild.
  11. 1st gen 4Runner Hardtop refurbish
  12. no oil pressure
  13. Headgasket help
  14. SmittyBilt Tubular Bumpers
  15. Dash pot screws are on tight!
  16. T4R first gen Can-Back soft top
  17. Iffy idle and start
  18. zinc
  19. Lspv help!
  20. Another Rust Post - Some Unusual Questions
  21. trasfer case 1986 4Runner
  22. charcoal canister delete
  23. 1986 Toyota 4Runner is running rich.
  24. Block drain fitting
  25. 1986 1st gen, bringing her back to life.
  26. Header w/o O2 port & OBD Code 25
  27. Need ideas on fix
  28. Loud rattle when cold
  29. 1990 4runner headlights
  30. 3vze code 52...knock sensor...what was your fix?
  31. Rust under the windshield.
  32. Cargo tie-down ideas
  33. 93 Toyota Pickup 3VZE Pulley
  34. my 91 4runner has no obviouse signs of blown gasket but...
  35. Rough running 91’ 4runner 3.0 v6
  36. '93 front and rear bumper
  37. 3.0 lack of power, somewhat high NOX
  38. Noise out of airbox. makes a broken belt sound
  39. Safe Harbor - Trusted Shops
  40. ICM Test?
  41. Help needed!
  42. 88 4Runner Window Weatherstripping for Vent Windows Question
  43. W56 Forward Shift
  44. Need Pin Outs - Front Power Window/Lock Cross Reference
  45. Your opinion - replacement springs
  46. 93 4Runner: Repair Vs. Replace?
  47. Reground cam pics-Would you run it?
  48. bucket seats 1994
  49. Front wheel bearing
  50. Rebuilt 22re has a bad miss
  51. Do They Exist: Solid Axle '86 4Runner or '85 Turbo?
  52. 87’ 4runner pre-ignition, detonation, overheat, wont rev.
  53. 1990 22re brake issue
  54. 3VZE Valve Cover Gaskets and Camshaft Plugs
  55. How do I know if the torsion bars are turned up?
  56. Did you know you are on 4X4builds.net?
  57. tie rods end installation on lifted truck
  58. 1989 4X4 22re to RET conversion?
  59. halp. 1992 truck bed extended cab vs regular cab
  60. w56 won't go into 5th or reverse?
  61. Idle issue 93 4runner
  62. Help with shift bushing collar installation
  63. something broke on rear axle
  64. Fan shroud
  65. 91 4Runner 3vze no start. SOMEONE PLEASE SCHOOL ME
  66. 84-86 T4R front grill TOYOTA badge
  67. Steering Gear Housing Replacement
  68. Fuel Filter Tubing Routing Question (1987 22R PU)
  69. Interchange Dizzy Pickup Coils?
  70. Pickup Coil Interchange: 1988 v. 1992?
  71. Code 24/31/25 rough idle.
  72. Rear axle alignment
  73. Some things I learned when doing my 22RE head gasket...
  74. Code 52 and 14
  75. 1992 4Runner has been bucking, stalling, and lagging on acceleration when warm!
  76. Trail Gear T case problems. Won’t shift into four low
  77. 86 4x4 22r Removing Emissions
  78. Can anyone identify this computer
  79. Rear bounce between 38-45mph
  80. A/C & Idle-Up Problem ?
  81. 3vze rebuild or swap for another engine?
  82. Clunking noise over bumps - I can’t find what’s doing it!
  83. Jack and tool Stowage 92 4X4 pickup reg. cab.
  84. 93 22re value?
  85. New guy with 94 SR5 pickup
  86. no brake issue
  87. Brake Light on Dash
  88. 22re timing issues
  89. 1993 22RE Engine miss/hesitation/power loss at random times - lasts one half second
  90. 91 Pickup front end upgrades
  91. Checklist for an Auto to Manual Swap
  92. New Head Casting Suggestions 22re
  93. Please help!!
  94. Cam wear opinions
  95. I need help with my 2wd 89 Toyota pickup sr5 extended cab I can't find lift spindles
  96. TPS code 41 even though TPS tests out fine
  97. Odd Clunking/ratteling sound from front end
  98. 22re air puffing out oil filler hole
  99. Oil puddle around spark plug hole
  100. Lateral Rod Difficult Installation, OME HD 2" Coils
  101. 89 Toyota 4x4 hesitation 22re 2.4L
  102. 22re random miss
  103. 3VZE plug wires?
  104. Electric fan install
  105. 94 4Runner a/c (22RE)
  106. Fan and Alternator Belt: 22R-E
  107. Tailgate Window Regulator Mount Brackets?
  108. T4R first gen stripes
  109. no power to fuel pump 22re
  110. 89 22re 4runner cut tps wires need matching
  111. 87 Pickup hood latch
  112. How loose should 22re timing chain be? (Loose guide also)
  113. 22re no ignition after ECU short
  114. Lower ball joint issue on pre-Tacoma trucks?
  115. T4R first gen 88 22re low idle at warm/hot start
  116. 86 4runner hub problems
  117. 22r in place of 22re
  118. 22RE Oil Leak
  119. I replaced my fuel pump and missed placed a hose
  120. Back seats
  121. "REAR DOOR" light blinking, driving me crazy
  122. Is 22RE/OSK T011K kit supposed to come with OSK timing chain?
  123. Does anyone know what the heck this is??
  124. Trouble shooting rebuilt 3vze
  125. 1st gen 4runner power loss
  126. Parts Names and Functions
  127. Help a newbie out! 95 Pickup 4x4 V6
  128. Parts questions
  129. How many quarts of oil?
  130. Mk3 seat installation
  131. Obnoxious squeak
  132. gears
  133. High Idle
  134. Engine swap or rebuild? 22RE for 2JZ (86 4Runner)
  135. AC conversion on 350 swapped 92 Pickup
  136. Fuel line.
  137. 3VZE Overheating Issues
  138. Jumped the fuel pump via diagnostics ..nothin
  139. is there a good cam for offroad and daily highway use?
  140. Help identify this 22re mystery clacking noise
  141. Trany thermostat location?
  142. 1986 toyota pickup 22re port underneath cold start injector?
  143. My 1988 xcab build
  144. Special Owner's Manual for 4x4?
  145. My $1100 mistake
  146. seat belts swap from right to left?
  147. Taillight Bulb
  148. Exhaust system replacement Q&A
  149. Question for those who have bought new carpet
  150. Still a hard time shifting
  151. Fuel Pump Recommendation for 1987 PU 22R
  152. Idle Issue 3vze (Video)
  153. 91 pickup. New head opinions
  154. What plugs into this ground beneath air intake?
  155. Pan hard bar TOO angled?
  156. Which ring is top?
  157. 1986 toyota is hard to get out of second gear
  158. Cooling system has me stumped
  159. Chassis identification
  160. Egr temp sensor
  161. Anyone know what wheels these are?
  162. 1992 4Runner 22RE Won't Start
  163. 1987 4Runner Check Engine Light on, cannot retrieve codes"
  164. 4wd actuator...sleeve stuck??
  165. 87 22r sputterin out at high rpms
  166. Intermittent Start Issue on 87 4Runner
  167. Filling transfer case thru shifter hole...but where did the oil go?
  168. 1986 Toyota 4Runner Instrument Cluster
  169. 1989 22re swap runs crappy
  170. Stumped over heating
  171. 88 22r Electrical Nightmare
  172. Where can I get this Part?
  173. upgrade for the ct20
  174. 95 pickup no spark
  175. What's up with Engnbldr.com?
  176. Do not try this at home!!!
  177. Difficultly finding power side view mirrors 87 4Runner
  178. Are 4Runner side mirrors larger than pickup's and will they swap?
  179. 1992 4Runner won't shift out of park after replacing Transmission pan gasket
  180. '94 Pickup 3VZE, Odometer Works, Speedometer doesn't (DLX->SR5 Cluster Swap) Help!
  181. 3VZE timing retarded but no more room to adjust
  182. Interior
  183. Mounting Shocks Outside of the Frame
  184. help size bolts to use on a rotor cap on 1988 toyota v6
  185. 22rr 1990 2wd pickup Speedometer cable
  186. 1987 22r Hesitates on Acceleration.
  187. brake lights fixed now turn signal out!
  188. '94 Pickup 3VZE SR5 Cluster Swap
  189. 22RE detonation ping and knock sensor question
  190. Tire Pressure
  191. 95 t-100 No Start - lots tried but no fix
  192. 1991 22re build help
  193. 1991 22re build help
  194. Bendix Vac Booster on Toyota 4x4? NAPA says no!
  195. Help with power windows and locks
  196. Heater Core Replacement
  197. 1994 22re engine surging problem
  198. Resetting the steering stop bolts or procedure on adjusting (4" lifted IFS)
  199. Headlight/wiper tree assembly wiring harness 86 4runner DLX
  200. Air-conditioning compressor, belt and idler pulley - 22re
  201. front axle leak
  202. 3.0 MAF Factory Settings
  203. Where does this wire go?
  204. 4x4 engagement problem.
  205. 94 3.0 L V6 locked up
  206. 1986 22r Starter Relay difference
  207. First gear setup
  208. Getting hot!
  209. 1991 Pickup 4x4 Getting Warmer on Highway
  210. 1987 22RE Winding Sound....power steering pump? +++
  211. Chinese turbos
  212. Laundry List of 22re issues
  213. front drive shaft replacement
  214. mi 4runner 92 con motor 3vz no prende
  215. Looking for hood and passenger side fender for 87 Toyota 4x4 pickup
  216. Need help finding 87 4x4 comparables for insurance
  217. Dash lights into after transmission replacement
  218. suspension
  219. cruse control
  220. Load Sensing Proportioning Valve
  221. Trans leak
  222. 94 engine into a 90, cranking no start.
  223. Fuel tank and components
  224. New heads or....?
  225. 93 2nd Gen 4Runner Tail gate lock issue.
  226. Clutch chatter
  227. No Start!
  228. Rear Spring Options
  229. Old Warn Winch mounting points.
  230. Elocker Mod & 3rd gen sway bar
  231. Another noob with a noob type question
  232. Any info on this paint scheme? Please view!
  233. Clutch Bypass into Off-Road Lights Switch?
  234. 1994 4Runner start issues
  235. Where does this wire go (pic)? 93 4x4 DLX Pickup
  236. 89 toyota 22re starts fine but heats up and then starts idling crappy and hesitates
  237. Hard to shift into gear?
  238. What do i need to check? Fuse, wireing harness, etc
  239. LCE Header/Starter
  240. 4R first gen temp gauge doesn't work
  241. 22RE replacement
  242. 1994 toyota pickup rocker arm
  243. 1990 22re pickup 2wd motor oil ?
  244. 86 4runner 22re never warms to op temp, no radiator flow, no heat regardless of load
  245. Rancho RS60612 Add A Leaf Kit - What size U-Bolts?
  246. The sound of relays clicking behind dash?
  247. Growling When Moving
  248. 3VZE Thermostat Replacement
  249. Which ecu for my truck with not original engine?
  250. 2jz ‘90 2wd Pickup questions.
