Filling transfer case thru shifter hole...but where did the oil go?
Old 03-16-2018, 11:16 AM
Paul22RE's Avatar
92 4cyl: Finished clutch job and was refilling fluids: Filled my tranny thru the tranny shifter hole and worked great, started coming out of filler hole at the exact right amount. Then filled the TC at the TC shifter hole and nothing came out of the filler hole after almost 2 qts, put my finger in there and dry? Where did the oil go??? Is there a void between the tranny & TC. Nothing more came out of the tranny filler hole. Where is the oil???
Old 03-16-2018, 11:28 AM
millball's Avatar
There is a substantial void in the rear of the transmission case on a W56 type tranny for sure. I don't know what type tranny is in your truck.
I recently filled the transfer case in my W56 equpped 1987 4Runner thru the shifter hole and it did require more than 2 quarts before the oil came out of its filler hole.
My case was completely dry , as I had it apart for installation of 4.7 gears.
Old 03-16-2018, 11:33 AM
Paul22RE's Avatar
It is a W56, so the oil is stuck in the void now? Will this cause any problems?
Old 03-16-2018, 11:39 AM
millball's Avatar
No, the void is meant to be filled with oil up to the level of the t. case filler hole. It is necessary to lube the large bearings in the low range reduction part of the case.
Keep adding oil slowly so that everything can equalize. When there's enough, it will flow out the filler plug opening.
Old 03-16-2018, 11:42 AM
Paul22RE's Avatar
Great, I thought I screwed up big time. Thanks for the quick response!
69sixpackbee
01-16-2014 08:42 AM
Sandman
09-16-2013 01:07 PM
SR5
12-11-2009 09:57 AM
nomadic_addict
09-09-2009 07:18 AM
Quick Reply: Filling transfer case thru shifter hole...but where did the oil go?
