Dash lights into after transmission replacement
Old Mar 4, 2018 | 05:27 PM
charles.isbell85's Avatar
Dash lights not working after transmission replacement
so here’s what I have. I a 93 auto that needed a transmission. Swapped the tranny out and now my
ecu power light doesn’t come on and my 4x4 light doesn’t come on. They worked prior to the transmission going bad. I looked st all the wires everything is plugged in. When I shift into low range it works just those two lights aren’t working after the swap. Any ideas?
Last edited by charles.isbell85; Mar 5, 2018 at 07:36 PM. Reason: Damn autocorrect
Old Mar 5, 2018 | 07:37 PM
No one?!?!? Really !?!?!?
Old Mar 5, 2018 | 08:24 PM
RAD4Runner's Avatar
Originally Posted by charles.isbell85
... They worked prior to the transmission going bad. I looked st all the wires everything is plugged in.
Pls see my signature. See what applies to your issue.
Old Mar 5, 2018 | 08:36 PM
akwheeler's Avatar
how about telling the whole story? what motor, did you put in a used tranny or new? did you do the work? do you have a multi meter and a wiring diagram? test the electronics on the old tranny and compare to the new one? did you pinch any wires in the bell housing or t-case mating surfaces?
Old Mar 5, 2018 | 10:50 PM
Co_94_PU's Avatar
From what I recall of this era wiring diagram, the shift pattern selection switch operates independent of the ECU and transmission. Likely a loose wire under the console or dash..
Rapidrob
Feb 19, 2016 10:35 PM
kinsey.clay
Mar 10, 2013 12:27 AM
newTOyotas
Mar 20, 2011 04:09 PM
johnson1987
Dec 19, 2009 05:33 PM
