94 3.0 L V6 locked up
Old Mar 7, 2018 | 06:37 AM
Slipka26's Avatar
Hi, I just bought a 1994 3.0 V6 pickup. On my way to work this morning the engine started knocking and locked up. I am looking for info on options for what engine will drop in place of the 3.0L without too much extra work. The 3.0 just seems a bit scarce. Thanks!
Old Mar 7, 2018 | 06:50 AM
akwheeler's Avatar
The only "drop in" would be another 3.0.
If you were to post your location you may find someone in your area that has one to get rid of.
I will have one to pass on, I'm just not ready for my swap yet.
Old Mar 7, 2018 | 07:36 AM
Slipka26's Avatar
That would be great! I’m in Gillette Wyoming. If anybody has one.
Old Mar 7, 2018 | 07:49 AM
Slipka26's Avatar
Just curious...what are you swapping to?
Old Mar 7, 2018 | 08:13 AM
akwheeler's Avatar
I have a 3.4 liter v-6 I'll be rebuilding and an entire running Toyota T-100 with a knocking motor that I'll be using for wiring/ecu and anything else I need. I may be swapping the entire engine/trans/t-case and I'm looking into how that might simplify some of the re-wiring needed. I might just take what is needed to run and put it in an ammo can and run power to it. It will still be a couple of years before I get the rebuild done and start the swap. Check out my SAS build thread if your interested. I still haven't figured out how to attach a link. https://www.yotatech.com/forums/f199...er-sas-294858/ let me know if this works.
Old Mar 7, 2018 | 09:22 AM
Slipka26's Avatar
Gotha! Thanks! Yes your link did work. Good luck man sounds fun!
Sporin
Mar 10, 2003 05:04 AM
ALee27
26
Jan 25, 2003 04:07 AM
momo76
10
Jan 22, 2003 08:09 PM
cvlighthouse
Oct 9, 2002 11:24 AM
