shifter locked up
Old Jan 21, 2003 | 04:50 PM
momo76's Avatar
Unhappy shifter locked up
My shift lock just crapped out on me. when I press the button on top of the shifter it won't well... shift. It works when I stick something into the lock release. Any quick solutions???? please.:cry:
Old Jan 21, 2003 | 05:14 PM
PhxTRDRunner's Avatar
Do you have brake lights? Very well could be the brake light fuse, and/or the brake light switch at the pedel. Check to see if you have brake lights.
Old Jan 21, 2003 | 05:17 PM
Dr. Zhivago's Avatar
Away
See?
Auto Tranny =
I'm sorry you're having problems, but I HATE Auto trannies. Phx made an excellent troubleshooting suggestion, however.
My .02
Dr. Z
Old Jan 21, 2003 | 05:29 PM
FattyCBR's Avatar
On the third gens the shifter won't release unless your foot is on the brake. If it is the same with the 2nd gens the sensor on the brake pedal may be broken.
Old Jan 21, 2003 | 05:41 PM
rpeAMP's Avatar
Will it shift out of park if the override tab is used?
Old Jan 21, 2003 | 08:50 PM
momo76's Avatar
I tried the brakes and they DO NOT work. The fuse seems to fine. Where is the brake sensor located? Would a bad bulb maybe trigger this?
Old Jan 21, 2003 | 08:56 PM
minidisc8's Avatar
Its a round push button switch which should be located directly behind the brake pedal.
I had one go out on my corolla and it was kind a expensive if I remember right.
Old Jan 21, 2003 | 09:33 PM
pinoy's Avatar
sorry.. have no idea.. but i still love those new fender flares and clear tails.
Old Jan 22, 2003 | 10:20 AM
momo76's Avatar
Problem solved! The third brake light bulb had gone out, I had no idea a bad bulb would make the shifter lock up. Runners are just full of surprises,:rolleyes:
Old Jan 22, 2003 | 10:39 AM
Corey's Avatar
Co-Founder/Administrator
I have heard this before, but never first hand experienced it.
Have not had a rear bulb go out yet, in fact since owning my rig since Nov. of '98, I have only had a front turn signal go out on me, and that was about three weeks ago.
That is easy to tell, as the flasher in the cab will click real fast.
I guess this is a safety item Toyota does by locking up your shifter like that, but man, what if you don't carry a spare bulb?
I have spares I carry for the domes, rear, and fronts just in case one goes out while I'm truckin' down the road or trail.
Old Jan 22, 2003 | 08:09 PM
Good job, way to troubleshoot
mwisham
May 26, 2021 02:51 PM
briholt
Sep 20, 2015 10:26 PM
Jason4X4
Sep 17, 2015 08:02 AM
zz_denis
Sep 6, 2015 03:43 PM
eggens
Sep 5, 2015 12:16 AM
