Egr temp sensor
Old Mar 18, 2018 | 05:26 PM
Dirtydavis18's Avatar
Egr temp sensor
Can someone tell me what year models had the get temp sensor bought an 89 and the sensor is unplugged and no place in harness for it so that means year of motor may be different
Old Mar 18, 2018 | 06:20 PM
scope103's Avatar
The EGR gas temp sensor in my truck will also fit (some) trucks back as far as 1992. https://parts.lakelandtoyota.com/p/T...941234010.html So I'm pretty sure no models before that had the sensor, and so far as I know only California trucks had it.
So, congratulations! Your motor is much newer than the rest of your truck.
The sensor is used to monitor the operation of the EGR system, and report (throw a code) when it did not work correctly. Since you don't have the harness (and probably the ECM) for that sensor, you can just not bother using it. (Unless you're in someplace with smog control, in which case you might have trouble when the "disconnected" sensor is noted.)
94toy4x4fever
Mar 24, 2008 09:43 PM
94toy4x4fever
Mar 9, 2008 07:12 PM
amigowa
Jun 29, 2005 07:38 AM
quick2300
Jan 15, 2005 01:36 PM
NCSU
Oct 19, 2004 01:12 PM
