89 22re 4runner cut tps wires need matching
I recently started working on my 89 4runner 22re straight axle swap and I forgot that I had cut off the TPS plug to use on another vehicle which I no longer have.
The problem I’m having now is matching which color wire to which pin in the tps sensor.
my colors are blue black white brown. If anyone has the same color wires going to the TPS it would be awesome if you could let me know which pin takes what color.
Ended up tracing the wires from the EC you and found my coloring that photo help a lot though. Ended up having starting troubles after that my car would start run for a few seconds and shut off I replace the PCV valve mass airflow sensor air filter and fuel filter. Started up and it ran perfect
my truck is a 88/89 split year so a lot of the parts are different or the same
just curious does anyone have OEM height front leaf springs off an 84 or 85. If so I would trade you straight up for my trail gear 3 inch lift Springs brand new... I Really just want a low drivable ride height really just want a low drivable ride height for my SAS
I already bought the low range chevy swap kit and the chevy springs I’m getting are only 2+1 off a 05 chevy 1500.
any other suggestions for lowering the front?
i as well planning on running 33’s or 35’s once I have money to re-gear
It only has 117k original miles btw😁
tj884Rdlx
20
07-13-2011 02:07 PM
