no brake issue
Old Apr 6, 2018 | 09:21 PM
olharleyman's Avatar
no brake issue
OK so I replaced a front right caliper on my 93 4runner sas 35 12.5s 22re everything went perfect but brakes where very low and almost did not stop me. I and a friend who is a master ase guy with gm bleed the brakes and got a little more pedal after a couple more cracks of the bleeder the pedal was nice and high. I started the truck and the pedal went to the floor no brakes. So we replaced the master cylinder same thing then the it was a new brake booster still the same thing at wits end please help
Old Apr 6, 2018 | 09:49 PM
RAD4Runner's Avatar
You sure you bled thoroughly and topped off after each parts replacement? No leaks?
Old Apr 6, 2018 | 09:55 PM
yep lose all pedal soon as it fires up
Old Apr 7, 2018 | 01:46 AM
wyoming9's Avatar
Red face
Your sucking Air someplace .
All it takes is one spec of grit in a flare fitting .
Bleeder not sealing .
Your New Caliper has a problem ??
These can sometimes be a real pain to get all the air out of the LSPV lines when the valve is so rusty trying to remove the bleeder gets real expensive .
Old Apr 7, 2018 | 11:05 AM
RAD4Runner's Avatar
Bleeder not sealing
Just wondering... I think the system could only suck air from the booster vacuum, right? And vacuum leak would cause hard pedal but not cause it to go all the way down to the floor?
If bleeder not sealing, there should be a leak.
Old Apr 7, 2018 | 11:54 AM
old87yota's Avatar
Let me see if I can get this straight.
Does the pedal feel fine when the truck is off?
Then when you start the truck the pedal goes to the floor?
What brake parts are you using? You probably did some modifications for the SAS, right? What modifications did you do?
Old Apr 7, 2018 | 11:59 AM
yes rock hard when off
yes falls to the floor when truck is started
stock disk front drum rear was never an issue before replacing caliper that froze up
redbayredneck
Jun 2, 2014 04:29 AM
nothingbetter
Nov 11, 2013 03:40 PM
kevo4runner89
Sep 13, 2013 04:30 PM
Rob2thec
Jan 28, 2010 10:09 PM
