'94 Pickup 3VZE, Odometer Works, Speedometer doesn't (DLX->SR5 Cluster Swap) Help!
Hey again y'all. I'm in the middle of doing an SR5 cluster swap on my '94 3VZE DLX (Automatic). I disassembled my DLX cluster and removed the odometer and swapped it into the SR5 gauge, but kept the SR5 face/needle. I ran 18 gauge wire to the P terminal on the new cluster and swapped in the correct oil sender. When I fire her up the tach works flawlessly, no CEL, and the oil pressure gauge is not fried. I took her for a spin and noticed that while the odometer is correctly metering the distance driven, the speedometer needle does not move at all. Does anyone know what might be wrong here? I put the odometer that came with the SR5 cluster into my DLX cluster and tried plugging that in and the speedo doesn't work on that either. I'm really stumped here!
Fire63
04-02-2018 02:10 PM
