- Flashing parking/running lights on 1994 4runner
- Lift kits
- Small knocking
- '94 3.0 VZE 4Runner timing questions
- Rust repair
- 87 pickup resto
- 2nd Gen Square Grille Clips
- Budbuilt crossmember
- Transmission won't shift into 4th when warm
- Wont shift into L gear
- Sluggish 22re
- Engine rebuild
- Fuel Injector testing (injectors and their connectors)
- 1986 Toyota 4Runner Auto
- Motor swap & different EGR with temp sensor
- 1994 truck 2wd fuel line parts assistance
- Didn't clean zerk fittings....what now?
- Coolant leak need help!
- LOWERING 2nd gen 4runner torsion bars
- 4wd shifter questions
- Relay wired into ignition from PO
- Top of piston head
- Code 14&21
- Fuel pump bracket
- 22re wont idle
- Check engine light code 4 and 11
- Show me your Toyota factory stereo (85-88 Trucks and 4Runners)
- Looking for some advise :)
- If anyone needs pics of a stock 4Runner...
- 5-speed transmission fill plug (I did search!)
- Breaking issue 22re 2wd
- Code 43 question
- Code 43 question
- Refurb steering box in Canada?
- Hose / line fell out
- 3VZE Timing Belt Adjustment/Checking
- Best quality/heavy duty P/S pump?
- Simple Trans ?
- Speedometer gear
- Strange idle after timing belt - 3.0
- Left trailer turn signal not working, where is it located?
- tips for cleaning block surface
- RockAuto Knock Sensors?
- Bought Transmission with metal particles beneath shift lever ???HELP
- Temperature Issues and Uncertainity?
- How to - Pickup front brakes / rotors / wheel bearings
- Moving to Colorado - To Take My '86 or to Sell It? Grateful for your advice!
- CANNOT Get This Wiper Thing Figured Out!
- Rust prevention: might be worth taking those interior door panels off...
- Looking to purchase a pop up sunroof for '90 4runner
- Can you tell what this noise is?
- Power steering pump leaking under load
- Trans/Transfercase
- Wiring harness ID
- Truck running issues
- Exterior cab vent grill removal?
- Overheating offroad
- 94 4Runner Fuel Line leak
- Tailgate wiper not working after replacing glass rails.
- V6 oil cooler
- What does this VSV do?
- What are these wires for ?
- Please help damsel in distress!
- 200k
- Stereo Bracket Confusion
- Timing Chain Slack
- Steering Wheel Hub Compatibility
- Electrical issue w/ no start/crank
- Engine turns over and stalls 3vz
- 22Re Huge power loss/rough running Plz HELP
- Auto or manual transmission
- Rattling noise,not "Grinding" while accelerating in all gears???
- Interior color change without full swap
- 86 4runner Starts but stalls immediately
- 95 pickup 3vze Intermittent no start , terrible idle
- Looking for a machine shop in the Baltimore MD area 22RE
- How to Install A/C in a 1st Gen 4Runner/Pickup
- And another... grinding noise
- How do i find what transmission i have?
- Vacuum hose question
- RTV on intake manifold gaskets? (Knock sensor replacement related question)
- Power Steering Box Rebuild - Still Leaks...at a loss
- 92 pickup 22RE Stalling
- ADD front diff tube and seals
- Skidplate breakdown
- Fuel Pump Issues
- Lower Ball Joints
- Part Number HELP
- CSF Radiator Issue?
- LCE master rebuild kit premium or Eco?
- Identifying Unknown Camshaft in 22r engine
- 87 22r Ignition module
- Vacuum line to fuel regulator
- replacing alternator brushes without removing alternator
- another 94 4runner 3.0 cranks but won't start
- 1992 toyota pickup 22re 2WD payload
- Weird problem. Need advice
- Front Wheel Bearing Manufacturers
- 1992 3VZE engine coil problem?
- Need Help Identifying
- 1987 Toyota P/U Slave Clutch Cylinder Install Question
- 1994 4Runner Accessory power issue
- Replacing T-Stat on 93 4Runner
- About to install new exhaust manifold and egr valve 22re
- Head gasket rebuild
- 1993 4runner 3.0 V6 starts, idles rough and low, stalls.
- Do I need to replace the rear axle bearings?
- 1989 Rear U bolt Width?
- Will a 91 Factory Manual Cover A 92 Pick Up??
- Grinding noise while accelerating in 1st 2nd 3rd and 5th gear
- Setting idle speed question
- Starting issue after cleaning
- Idles at 2500 RPM
- My new daily/project
- Chasing a noise, found a culprit, asking advice
- '93 3VZ intake Plenum Hardware
- 4runner runs rough
- sc400 front wheel assembly on a 94 toyota pickup
- Shifted to 4th and shakes ensued
- Determining chassis number using the Amayama site
- 1994 Toyota 2WD Ext Cab
- 1994 Toyota WD Ext Cab
- How to Hook Up Fuel Pressure Tester???
- What is this???
- 1987 grill badge
- Steering Shaft Splines
- Timing Component Problems 91 3VZE
- Crankshaft Timing Notch Off
- Steering Column cover
- Transfer case not engaging
- 1995 4runner 3.0 no fuel pressure
- 91 Pick up Front Wheel Noise
- 1986 Toyota Pickup
- 91 Toyota pickup
- Can you identify this leak?
- 87 22RE Vacuum Leak
- Do you think I need a new cat?😹
- Grouping maintenance work?
- Rear Drum brake locked up
- Toyota truck second gen third brake light
- Just complaining
- Brake bleeding issues.
- 22re starts then dies
- Keep blowing 80A ALT fuse.
- AC diag help please
- Nuts and Bolts..common sizes
- Is this where timing is supposed to be with cyl 4 at TDC?
- Pickup Door Panels in Gen 1 4R
- First gen sliding window run replacements
- Power steering on 1990 4x4 4Runner
- 4Runner rear window sweep
- Front end work needed...lots of pics
- Blower only on low speed
- 1989 - Ranch truck - So much to fix
- Crazy starting issue 88
- Brake pedal pops while pressing sometimes.., Cause?
- Set timing after head replacement
- Thick oil buildup
- Backup light switch across models
- Timing belt woes
- A/C on idle drops
- G52 05 W56 Tranny Rebuild Part Source
- Defective diagnostic connector/plug for 93 4Runner
- Bobbing Idle and No Power
- Ome rear leaf install
- 4 runner wheels
- Front end grinding as well my teeth
- Temperature gauge
- Is there any bronze or copper in w56 tranny or rear diff?
- Two bad alternators or bad wiring?
- rear window removal / installation
- 4Runner cargo panels
- Anyone know what these are? Suspension lift...
- What 2nd Gen rear springs are these?
- Restoring A/C for 91 3vze
- Another no spark!
- Steering stabilizer?
- New plugs, wires, cap and rotor, now runs worse than ever
- 88 22R no spark, no power to coil, runs if I inject power to IGN fuse holder
- Auto to 5spd swap help!
- 91 pickup lift and tires
- Mounting a winch need suggestion
- Code 25 (lean) but actually is rich
- Lower Control Arms Bushings
- rear wiper not seated - rear window issue
- 95 pickup failed smog-exhaust leak
- 95 4Runner Transmission
- Should I buy this old Toyota 4x4?
- 92 4Runner No Crank/No Start
- 22re rebuild
- R150 second gear
- 22re EGR union nut size...
- 1990 Toyota pickup 3.0 check engine
- Leafs fir 91 close to stock height but good quality
- Clacking noise in front suspension- can’t identify
- 95 4runner 3VZE Coolant/Starting Issues
- 2nd gen tailgate weatherstripping clips?
- 87 Toyota 4x4 Squeals When not Braking
- Are Automatics supposed to lock with no key?
- Father daughter project.
- Help identifying wires behind stereo area
- 94Runner Drive line 3VZE to 22RE
- A/C button - 1987 pickup
- Looking at an 89 4x4 pickup??
- Help: Parts list and pricing for new gears and lockers
- 92 pickup high idle?
- Rotor Replacement/Hub Removal
- What size are the tailight bulbs on the 1990 4Runner with the spare tire carrier?
- Help with metal backed guides
- Code 52 knock sensor and a loose valve.
- 1986 toyota pickup turbo engine problem
- 7.5 Front Diff Stub Shaft Wobble
- Emissions failure
- Front Brake Upgrade
- These are the only dash warning lights I have
- Parts!!
- 22re Long crank time only When it been sitting for a hr or 2
- photoshop paint job
- 1994 Toyota ac problems
- 4Runner Rollbar Mounting Holes - location & configuration
- 91 pickup brake issue
- center console switch LEDs
- Dodge 3.7 swap
- Add a leaf retainer clip needed?
- Sloppy shift lever in 86 4runner dlx a/t
- Lift questions for 89-94 trucks
- High idle
- Need a valve (I think) ID'd
- Swapping 22RE TPS
- 94 Toyota Pick up Advise
- Help identifying this vacuum line 3vze engine
- Help Identifying Part 1987 Truck
- Value of 1987 Pre-runner
- Code 25 troubleshooting
- LPSV won't bleed
- Replacing Wiper Arms 1994 DLX
- 2nd gen vs 3rd ged standard bed sizes
- What is the purpose of a rocker arm spring?
- Having an issue with idle surging 95 toy
- W56 trans 3-4 synchro assembly
- How to remove PU B-piller trim?
- W56 trans
- W56 trans
- '(94 toyota pickup 95K on 22RE) coolant hose barb part #??
- Rough ride
- 3vze oil leak sources
- My '92 T4R on 35's
- 89 22re FUEL PUMP SHORT?
