Help with metal backed guides
Old Apr 28, 2020 | 08:09 PM
doozer96024@gmail.co's Avatar
I am putting my motor back together and the metal backed guides from Mizumo auto have one hole slotted on both guides anybody else use these if so did you put the bolt in the middle off the slotted hole or pushed one way or the other I'm thinking pushed in so the chain has the least slack but would like to hear from somebody else what they think or have experienced
thanks
Tommy
Old Apr 29, 2020 | 08:01 AM
Old May 2, 2020 | 05:24 PM
That's what I went with but the aftermarket timing cover has 2 high corners stoping the head gasket from sealing and maybe the oil pan as well just in case anyone is thinking of ordering from them
Old May 3, 2020 | 07:20 AM
Co_94_PU's Avatar
Your timing cover is typically milled to match your deck height of the engine block.
Old May 3, 2020 | 07:42 AM
I didn't have anything milled off my block
Old May 3, 2020 | 07:46 AM
One corner of the oil pan side is to tall also
Old May 3, 2020 | 08:19 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I know the oem covers are pricey, but you can get the Aisin cover at a fair price.
What brand did you try?
Old May 3, 2020 | 10:14 AM
Came in the same kit it has everything but from different manufacturer I can't find a name on the casting I'm cleaning my old one today so I can see if it isn't warn all the way threw
rancherman
Dec 29, 2017 10:52 AM
shudson248
Mar 7, 2016 06:18 PM
Larz28
May 28, 2013 07:41 AM
WHEELER8688
May 15, 2012 03:48 PM
DanStew
Nov 11, 2007 08:41 AM
