My first!! Toyota 4x4
Old Feb 27, 2020 | 10:56 AM
Jaketheone46's Avatar
Hello to all, my name is Jake
Back in the day my grandpa had 2 Toyota 4x4,(not at the same time) the first one was the tan color I would guess to be a 1980 and the second one I would say it was a 1985. (Also tan) Both were bought brand new and used for everything including being a farm truck so I got to see how capable these trucks are way back then. I’ve always wanted one ever since. My oldest brother bought a brand new 94 which was the last of the good ones. I love these old trucks because of how small and capable they are. I’ve looked on and off for years and finally started looking more seriously a year or so ago. Finally found a 1990 Toyota 4x4 in pretty good shape and very little if any rust. The frame looks great, I see a bit of rust forming behind the pass rear wheel if you look under the bottom of the quarter. 1 other spot in front of the pass rocker. (surface only) The truck runs and drives great. Just wanted to get on here and let everyone know I’m now part of the family. I’m stoked!! I’ve wanted one of these trucks bad for years. Looking forward to taking it off road a bit for sure. Oh yea it has Mickey Thompson wheels and tires!! Tires are a bit big for my taste so I’ll be looking to get a set of tires that are closer to the stock width. Perhaps a set of 31-9.5-15s or 29-9.5-15 I’m not sure what will look best. For now it’s time to service the engine,trans,transfer case,& both diffs with some good stuff. I will have to figure out what goes in each. I do know I’ll use mobile 1 engine oil not sure what to use in any of the others yet. Time for some research.
Old Feb 27, 2020 | 11:11 AM
SomedayJ's Avatar
Glad you got it and don't forget to post some pics, Jake!
Old Feb 27, 2020 | 01:56 PM
jakey poo's Avatar
Sorry Jake but with @old87yota and myself I think this site has made its Jake quota.
All kidding aside welcome to the site!
Old Feb 27, 2020 | 04:33 PM
Thanks guys, I will have to figure out how to post pics so you can see it. I definitely have a lot to learn about these trucks as well.
Old Feb 28, 2020 | 01:27 AM
old87yota's Avatar
Good thing my user name doesn't have my name in it, otherwise it could get confusing!
Welcome!
Old Feb 28, 2020 | 10:57 AM
5 Fists's Avatar
Welcome to Yotatech! Looking forward to some pictures!
Old Feb 29, 2020 | 12:05 AM
Welcome!
Yea no doubt, I am one of those that stick with the same user name for many forums so if you have any other hobbies you may see me around. My original user name is based off my all time favorite hobby which is motorcycles Jaketheone46 is my name (jake) followed by (theone) which stands for the Yamaha r1 then (46) is Valentino Rossi’s # the greatest of all time in moto gp Racing.
There are a few jakes on here for sure. If it helps I could always go by Jacob as well.
After all normal maintenance, changing all fluids ETC I want to lock up one of my diffs. I’m a assuming most do the rear but this is a daily so I want something I can install and forget about it. I’ve looked into the spartan, lunchbox type of lockers and they seem like a wearable item?? Is there something I can install for the long haul that will be fine everyday on the street?? Which makes me question would doing the front make more sense being I could use that type of locker up front being I won’t be in 4wd very often at all.
Also tires are priority as well, I have Mickey Thompson 31x10.50x15 currently with no lift and they seem a bit large for my taste, I prefer a thin tire and also wonder if 31” is a bit to tall as well?? I’m thinking 29” perhaps but not even sure if they make a 29” tire. I’m guessing 8.5” wide would look nice. Hopefully my current rims are not to wide. They are Mickey Thompson as well.
Old Feb 29, 2020 | 12:39 AM
Hey guys I’m sure it’s been mentioned in this forum many times. But another hobby of mine is the RC hobby. Radio controlled trucks and airplanes as well. But scale trucks are my favorite part of the hobby. Anyway a company called RC4WD makes a totally awesome Toyota scale truck that looks dam good out of the box. I prefer the kits so I get to build my own from the ground up. But they sell them in the ready to run version as well. It’s called the RC4WD Trail finder 2. Check em out if you would ever want a true to scale RC version of your touch. It does look like the early 80s version but it’s awesome with the leaf spring suspension and solid axles.
Old Mar 1, 2020 | 01:28 AM
helidriver's Avatar
They are fun to learn... This is a great site for info! And 4Crawler is a MUST read....
Old Mar 2, 2020 | 01:11 PM
What is 4crawler?? Being you say it’s a must read I’d like to check it out.
Old Mar 5, 2020 | 12:56 AM
helidriver's Avatar
Here you go, https://www.4crawler.com/4x4/ForSale/ProductLine.shtml
Old Mar 6, 2020 | 11:33 AM
RJR's Avatar
RJR
Concerning lockers, I put an Aussie (lunchbox type) in my front diff and I love it. The only downside is it's a little tricky on snow/ice, but I have other vehicles for primary snow use, so it's not much of an issue for me.
The locker works well on trails. It actually gets up rock ledges better than a rear locker, because the front wheels are pulling you up and over, instead of just being pushed against the ledge by a rear locker.
You'll also need to install manual hubs to accommodate the front locker. The ADD won't completely disengage the front drive shaft with the locker installed, so everything will still be spinning when driving in 2wd unless you can unlock the hubs.
Old Mar 6, 2020 | 05:07 PM
Mine does have manual hubs, I figured they were stock?? Did the 1990 Toyota 4x4 pickup come with auto locking hubs? Mine are the aisin manual locking hubs.
Old Mar 6, 2020 | 06:54 PM
RJR's Avatar
RJR
Not sure when they went to auto hubs or ADD (auto differential disconnect). I know the 93 and 94 had ADD. Whatever, if you have Aisin manual hubs, you're all set for a front locker.
Old Mar 7, 2020 | 04:05 AM
That’s awesome, from the research I’ve read mine would have come with the hubs that are just always locked unless ordered otherwise. They do work very smooth which is cool. I definitely want to lock front and rear too eventually and am trying to figure out what’s best for each end and which to do first. My concern with these cheaper style ratcheting lockers is wear. The clicks would not bother me but I’ve read good and bad about them wearing and needing replaced. My first thoughts would be some of the bad would be from bad installs.
Old Mar 7, 2020 | 10:15 AM
RJR's Avatar
RJR
Assuming you unlock the front hubs when on pavement, you should never wear out the front auto locker, since it will only be turning when offroad in 4wd. Obviously a rear auto locker will get exercised a lot more. I personally wouldn't put an auto locker in the rear of a daily driver; they're can be noisy and change the cornering characteristics significantly. I'd save up for a switchable locker in the rear, or put in an LSD like the True-Trac. My combination of front auto locker and rear TrueTrac is very effective offroad, and doesn't affect onroad driveability on dry pavement at all.
Old Mar 8, 2020 | 01:58 PM
I was thinking the Detroit locker for the rear, from what I’ve read they are very strong with no maintenance required.
Here’s a question, I’ve noticed that 3000 rpms seems like your revving the engine pretty good and the peak HP of the 22RE is at like 4600 RPM with a redline of like 6000 RPM and even 4600 RPM seems high to me. I’ve not went above 3200ish maybe 3500 and that seemed like I was ringing it’s neck. Its still pulling at that point but just seems excessive. I have thought about this and think perhaps the extremely flat power curve with the early torque makes it feel like that??? It seems as though it makes the same power from 2000RPM through 32/3500RPM and perhaps all the way to redline but I’ve never came close to that and never will. I’ve noticed you can drive the thing like a diesel. I shift at 2000rpm maybe a bit higher going into 3RD being the 2nd to 3rd gap seems a bit larger than the others. You can seriously lug the thing. If driven at these lower RPMS I could see getting 500k out of one of these engines.
Old Mar 8, 2020 | 08:25 PM
RJR's Avatar
RJR
I've never owned or driven a 22re, but I can say that you definitely have to push the 3ve V6 past 3000 rpm or you won't get anywhere. When accelerating, I upshift my 3vze at 4000 rpm regularly, and also generally run 4000 rpm continuously up the long mountain grades here in Colorado. It'll run all day under those conditions and love it.
The 22re has somewhat bigger pistons and a longer stroke, so may not rev quite as well, but with a redline of 6000 rpm, I wouldn't hesitate to push 4000 when I needed some power.
Low rpm at wide open throttle (ie, "lugging") is not a recipe for extra long engine life. Cylinder pressures are generally higher under those conditions than at higher rpm's, translating to greater stresses on the rods and crank journals and possible increased risk of blowing a head gasket.
Old Mar 8, 2020 | 09:11 PM
OldBlueMidnight's Avatar
5 Year Member
Regarding the diff's I like the Trutracs I put in my rig pretty well. Probably not as strong as a Detroit locker, but a locker in the rear can get you into trouble in slick conditions on the street, and the Trutracs don't have any wear parts. https://expeditionportal.com/forum/t...-street.57696/
Old Mar 9, 2020 | 12:58 AM
Oh I won’t lug it under heavy throttle whatsoever, I just upshift at the lowest rpm that it will take the next gear smoothly which is lower than most engines I’ve driven. This also is only on flat ground and when I’m in absolutely no hurry. I have noticed it really does no good to get in a hurry anyway being when you do rev it out a bit it doesn’t seem to pick up any faster. It’s pretty easy to tell when the engine is not liking the lower rpm and when this happens I’ll go back a gear. This thing is just a really smooth engine with a super flat power curve. I definitely don’t lug it under any type of hard throttle.
