92 pickup 22RE Stalling
Old May 25, 2020 | 12:02 PM
Steky's Avatar
I have a 22 RE pickup I recently purchased. It hadn't ran in over a year before I bought it. I drained the fuel tank and replaced fuel filter and got it running. Had cel for bad AFM, replaced it with one from NAPA. Codes went away, starts ran great for about 80 miles. Now it intermittently stalls while driving. It will start right back up and run fine. Doesn't do it every day, checked for codes this morning and none showed up. Anyone have any ideals?
Thanks for your help.
Old May 25, 2020 | 02:10 PM
GrandPrix's Avatar
Coolant temperature sensor?
Old May 26, 2020 | 06:19 AM
Steky's Avatar
Man I think your right started watching the temperature needle and it does occasionally do a quivering think. Do you know where this is located?
Old May 26, 2020 | 02:18 PM
GrandPrix's Avatar
Passenger side under the air intakes by the throttle body. A YouTube search will help. Easy fix. Get a good quality sensor. OEM or Napa.
Old May 26, 2020 | 03:21 PM
Paul22RE's Avatar
5 Year Member
Temp sender for the gauge has nothing to do with the ECU, there is a 2nd coolant temp sender for the ECU near the front of the intake.
Old May 26, 2020 | 04:48 PM
GrandPrix's Avatar
Lots of good YouTube guidance.
LaterHolmes
Mar 13, 2016 03:02 PM
nucleus
Jul 22, 2012 03:49 AM
shadytree
May 15, 2011 04:12 PM
crazy4ink
Apr 1, 2009 06:47 PM
David_mx70
Apr 1, 2009 12:57 PM
