Grouping maintenance work?
Old May 14, 2020 | 12:02 PM
wykp's Avatar
I have the following maintenance jobs in the near future for my 95 V6 4wd 3vze and was wondering which ones I should knock out together and which jobs should take priority. Suggestions are appreciated!
- Pinion seal replacement
- CV axles replacement
- Steering linkages replacement
- Sway bar links replacement
- Upper & lower control arms bushing replacement
Old May 16, 2020 | 09:07 PM
Jimkola's Avatar
YT Community Team
5 Year Member
The pinion seal and sway bar bushings can each be done stand alone.
The cv axles will be easier to do if the control arms are out of the way, and both the control arm bushings and the steering components would require a alignment afterwards. So I’d try and do those three items together. Or at least do the cv axles and control arm bushings together, then do the steering components just before getting the alignment.
Old May 17, 2020 | 02:10 PM
wykp's Avatar
Thank you, Jimkola. I really appreciate the advice!
Old May 17, 2020 | 02:42 PM
wallytoo's Avatar
the pinion seal and sway bar busings are fairly basic jobs, and can be done in about 1 hour each (less if you've done them before).
86Original
Mar 4, 2022 02:46 AM
Bumpin' Yota
14
Sep 26, 2004 07:59 AM
grams72
May 18, 2004 11:03 AM
Jboy
Jul 4, 2003 07:45 AM
