87 22RE Vacuum Leak
Old May 15, 2020 | 07:56 AM
GooseMan's Avatar
87 22RE Vacuum Leak
New to the forum, so apologies if this is in the wrong spot. I just put a new long block in my 87 4runner, and used the original intake. It will fire up, and run on carb spray, but dies out quickly. I found a massive vacuum leak, but I have not been able to find how to fix it. It's a small port underneath the cold start injector and for some reason I haven't seen it on any diagrams. If anyone can help identify this it would be greatly appreciated. Thanks in advance!
-Goose
Old May 15, 2020 | 08:51 AM
Jimkola's Avatar
YT Community Team
5 Year Member
The hose that goes to that port runs straight down and connects to the back of your idle air control valve (IAC) under the intake manifold
the part# for the hose should be 22234-35010. But please confirm the application before ordering/buying.
Old May 15, 2020 | 09:35 AM
GooseMan's Avatar
That makes so much sense, thank you. I'll try connecting it with a piece of hose and see if that works.
BUST'EM504
Sep 23, 2011 06:10 AM
BajaRunner
Sep 10, 2010 05:02 AM
horvath
May 2, 2009 07:18 PM
vdubyah73
Oct 30, 2005 09:35 AM
GregStevens
11
Nov 17, 2004 06:58 AM
