Vacuum Leak Problem Areas 22re
Old Sep 9, 2010 | 06:39 PM
BajaRunner's Avatar
I've replaced all my vacuum hoses, and intake plenum gasket. I've replaced the TB gasket, also have made sure I don't have any leaks in the intake hose (Mine is aluminum tube). I've replaced my PCV, and PCV grommet.
I've used a propane torch, like I usually do for leaks, as well as carb cleaner and water.
I still feel that I may have a vacuum leak because it runs good in open loop and bad in closed loop. The open loop runs richer and overshadows my vacuum/lean mixture.
Can the fuel pressure regulator itself cause a vacuum leak if bad? What other things do I need to look for?
Any help would be great. Thanks.
And nice new "smiley".... :wabbit2:
Old Sep 9, 2010 | 06:41 PM
thralldad's Avatar
Brake booster?
Old Sep 9, 2010 | 07:09 PM
BajaRunner's Avatar
Good call, never checked that one
Old Sep 10, 2010 | 05:02 AM
thralldad's Avatar
icentropy
Sep 16, 2020 02:47 PM
steve miller
Oct 10, 2015 01:40 AM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
