bad vacuum leak where to start???
Old Sep 21, 2011 | 05:26 PM
BUST'EM504's Avatar
Well I have been under the hood for 2 hours trying to find this damn leak and can't find it any help?? The good news is it sounds like I have a cam in this som ma bitch
Old Sep 21, 2011 | 05:32 PM
b4wheeler's Avatar
Start spraying carb cleaner or ether around the vacuum lines and when you hear a change in the idle, you wil have found the leak...
Old Sep 21, 2011 | 05:37 PM
mountaingoat's Avatar
How do you know it's a vacuum leak?
Old Sep 21, 2011 | 05:46 PM
BUST'EM504's Avatar
I not 100 percent but I can hear it sucking sounds like vacuum
Old Sep 21, 2011 | 05:58 PM
BUST'EM504's Avatar
I sprayed the whole motor down with starting fluid and it's still running rough and rich. It's idling about 600
Old Sep 21, 2011 | 06:01 PM
BUST'EM504's Avatar
I also just changed the water pump but I don't think that has anything to do with it
Old Sep 21, 2011 | 07:25 PM
westjohns yota's Avatar
is your timing set right? might have jumped, injectors clean? it can be more then a vaccum leak, also some vaccums are connected to the brake booster which has a seal that tends to go bad, thats what happended to mine causeing it to run rich again mines carbed but its the same principle, good luck!
Old Sep 22, 2011 | 07:06 PM
BUST'EM504's Avatar
Well good news I started her up today still ran rough .decided to take a little cruise I'm pulling back in the driveway she started purring like kitten
Old Sep 23, 2011 | 12:53 AM
TNRabbit's Avatar
If it sounds like it has a souped up cam, could be the EGR valve sticking open or a bad vacuum distribution disc.
Old Sep 23, 2011 | 06:10 AM
BUST'EM504's Avatar
I thought something like the egr or pcv is there a way to delete this emissions crap??
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
voiddweller
19
May 2, 2016 09:10 PM
Sandman
Jul 23, 2015 08:15 PM
JF9243176
Jun 24, 2015 04:53 AM
