Sponsored by: CARiD
Please Help before I lose my mind!
Old Jun 24, 2015 | 04:53 AM
JF9243176's Avatar
I recently bought a 1988 4runner v6 3.0 4x4 automatic has 3vze motor. It has some serious oil leaks but other than that ran fine during test drive. Drove for a week checking oil everyday, was all good. Went to get in it and checked oil none was showing on the stick. I only had 2 quarts available. I put those in and drove in to maintenance bay at work and had mechanic put more in. Well I guess he didn't check after he put oil in and neither did I before I drove it. I drove home which is about seven miles away. Everything was fine during drive. I didn't get in till about 2 days later and went to start it up. It was hard to start so gave it gas. When it cranked it was missing real bad and as soon as I let off throttle it stalled immediately. I checked oil and it was about 1 1/2" above full line. It needed a tune up anyway so I drained oil to proper level, changed plugs, wires, distributor cap, and rotor. That helped to quick start but still no idle, just stalls. I know from research it is vacuum leak, throttle body, or vane wind meter. I cleaned throttle body, mas and changed gaskets on them using proper torque. I tested hoses with vacuum tester and everything seemed to hold. I could not get vacuum on throttle body or EGR disk? I don't know if was doing it correctly. I also noticed small traces of oil that leaked out from intake manifold gasket. Where should I start now? Would a slight leak from intake manifold cause it to create such a vacuum leak that the engine will not idle? Also don't know proper way to check and see if EGR is stuck in open position? Any ideas would help. I hooked diagnostic machine to it but said vehicle is not responding or cable not connected. It was connected ok so don't know much about that either?
Thanks
James
ashamsuddin
17
Jul 22, 2024 03:59 AM
puddlepirate
Jul 30, 2016 06:29 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Keithstoyota
Sep 27, 2015 07:29 AM
