Setting idle speed question
Old May 19, 2020 | 12:41 PM
shafner30's Avatar
So when you go set your Idle speed with the screw on the throttlebody after you set the idle speed Would you Have to reset the ECU / throttle position sensor buy disconnecting the negative battery terminal or pulling the fuse for the ecu do you just think it’s OK not to do any of that?
it’s on a 1990 22re pickup manual transmission
2002 4-runner lover
May 11, 2010 07:43 AM
Tacoma74
Sep 27, 2009 06:27 PM
Texas_Ace
Jan 7, 2009 01:07 PM
aowRS
Jan 20, 2005 05:42 AM
Joyota
Nov 8, 2004 08:05 PM
