- 86 4runner idle issues
- Was NOT expecting this...3.0 piston damage
- ARP headstuds 3vze installed
- 1993 SR5 4runner build
- Messed up tranny........
- Looking for 91 22re cpu
- quick question on removing wheels-93 3vze sr5 4rnr
- Rear axel swap 1994 4x4 pickup
- Lower control arms
- 91 4runner front end making grinding and rattling noise
- Freaking vacuum lines...
- 22re wet the bed on me
- Timing - With New Parts
- Happy Birthday
- 1jz swap?
- 94 4Runner Blower Motor Not Working, HELP!!!!!
- IACV port in TB
- GOD gives me Oil..Y?
- Dual case question
- building dual cases
- 4Runner stuck in deep water - No snorkel
- Lift, Tires and Gears opinions and pics.
- rear differential fluid was almost dry ?
- Oil leak
- Anyone ever use a china made replacement carb?
- Anyone have a write up on 1st gen rotor replacement?
- Zuk mod on my 1987 4Runner using TJ springs
- rear mian seal
- E-Brake light stuck on.
- Timing belt help!!!
- 86-95 Trucks & 4Runners>Help: IFS diff - swapping longside ADD axle w/non-ADD axle
- 3vze temp goes down quick
- What is this thing? Back of "sr5" gauge cluster
- No heat 91 4runner
- Electrical gremlins in 93 4Runner 3.0
- 3VZ idel cut out probleme
- '93 SR5, 4x4, transmission issue, looking for advice
- fitting near thermostat housing?
- Changing water pump on 86 2.4 truck??
- 88 4x4 (3vz) transmission, transfer, and diff fluids checklist
- 90 4runner--lost 3rd and 4th gear
- Truck turns over but won't start -please help
- A340 transfer shift solonoid part #?
- Transmission Information
- setting 3vze distributor
- 1987 4runner, cant find right heater core
- toyota 4x4 ext cab
- Non-ADD diff in ADD truck?
- rad cap pressure?
- 22re timing
- ECU Tach wire?
- Gas Gauge doesn't work completly! What's Wrong!
- 1986 2wd p/u not running and weber carb swap
- My 1992 4x4 4cyl 22re Daily Driver
- where to find lower raditor for turbo pickup
- 1990 4runner engine codes
- Rough Idle and Drive from Cold Crank
- 22R hard to start
- 1990 toyota pickup 22re windshield whiper help
- 1991 3.0 4wd manual pickup fuses.
- 3.0 Surging 1800-2400 rpm
- 1+1=1 86 4Runner Project
- dash lights not working
- AMSOIL synthetic 75/90 Gear lube in manual 5 speed transmission
- Gearing question to get better mpgs.opinions !! And experienced answers!!
- Another Idle look over
- Dizzy ?
- will an 95 lift kit fit a 88 4runner
- What to order for axle?
- Suspension work- best place to get parts and recommendations
- Can I cut up an SR5 cluster to put after market gauges in?
- Overheating and belts squeeling
- LC Engineering Guage Pillar Install (PICS)
- 1994 22re
- 1995 4runner lost 3rd and 4th gear-clutch bracket broken
- 4runner brake issues
- Toyota 22r idle issues
- W56 trans questions pros cons topshift vs forward shift
- '90 4Runner idles too high and stalls
- White smoke
- Brake Pedal Woes
- V6 Spartan Locker Issue
- 1992 4runner new to 4x4
- 3vze upper intake lines?
- 1989 Toyota 22r 32/36 weber problems. Help!
- 88 4runner lights/cruise questions
- Fuel Door Stuck...Need Help
- Speedometer cable replacement
- Vibration at 50mph or higher
- 91 OEM Tire Carrier Maintenance
- need a quick measurement or two
- 1996 bed on 1990 truck?
- 1994 4X4 Pickup 22re Cold ignition problem
- I believe I might have a blown gasket?
- killing the truck. POWER!! 22re plow truck
- 91 toyota 4x4 weird noise please help
- Need help identifying part!
- 91 22re code 14
- New full rear leaf packs for 132$ a pair... shipped!
- what code?..
- who makes rear bumpers for 2nd gen 4runners?
- Converted to H4 Headlight, Wow, I can see...
- 92 toyota 4runner 4.88 gears ??????
- Custom panhard bar brackets?
- Brake upgrade
- Official snow pic Christmas thread?
- down-broke in roanoke
- Radiator 4x4 vs. 4x2 will it fit
- Noob looking for help
- Odd, intermittent, squeaking coming from front wheels?
- 89 toyota pickup extra cab
- 1991 4Runner head gasket repair
- Bad wiper switch?
- High beam not working when pushed, but works when pulled. 1/2 works
- 35x15.5 Super Swamper TSL SX on 15x8 wheels - Pics Inside!
- Transmission will not line up on the bottom 95 4runner
- o2 Diagnostic problems (code 25)
- 1" bodylift
- 87 4Runner Brake and Charge light on, alternator bad
- Help!! Electric fan problem! Melting fuse boxes!
- 95 4runner seat swap with a 92 Toyota pickup
- A plea for diagnostic help! 3VZE
- Trail gear bull bumper mod?
- 1994 4x4 Pickup Control Arm availability
- head gasket thickness ?
- Need to re-gear with 31's ??
- 22re coolant hoses under intakeM. - any ideas?
- Clutch replacement question
- 22RE "ticking"
- 1991 4runner seat swap with 1997 4runner
- Need help with gears
- Wheel bearing? floorboard
- battery and brake light on
- 1994 V6 4Runner low idle/stalling issues
- Lifted 4x4 88 pickup transfer case issue.
- Winch installation question - bullbar not suitable?
- 37's with 22RE, 5spd and stock 4.10 gearing?
- Digital Dash
- Which efan
- to rebuild my 22r
- 1st gen: Snorkel Install - Easy?
- clunking sound
- Is this an igniter problem?
- New Beginings - To build or not to build.
- BUY with a CODE 52???
- Wire harness swap question
- Build up on #1 spark plug
- far from home, overheating 3vze
- 86 sliding glass rear window on a 92?
- 1990 4Runner window problem fix
- Doug thorley header problem!!
- Has anyone heard from James Dean lately?
- Wabfab Perfect parts
- 86 -89 toyota pickup fsm help
- Autozone universal coolant
- clutch slipping
- bad vibration after SAS
- Gearing
- newbie Toyota owner 22re
- Exhaust Leak
- death wobble
- 86 22r wont start unless you pour fuel in the carb but theres fuel to/in carb!?!?!
- New owner - 87 4runner! A beast!
- Reman recommendations
- Tach reading low.
- 3vze diagnostic Code 24...shudder/miss/rough runner
- jaguar alternator swap 120
- Loud Whining Noise when turning the steering wheel and when pressing the brake pedal
- 3.0 3vze wont start after new belt
- Need help on 2,000 rpm idle and loping
- Found oil around knock senor when doing headgasket????
- head light not adjusting.
- Fixing Ign. bypass, need some wiring help..
- 1991 Sr5 intermittent engine issues.
- Where is the AC low pressure switch located 1987 pickup
- pulling 3.0 for 3.4 swap
- Truck Won't Go
- Catalayc converter
- Auto transmission issues
- Engine surge from hell...what could it be?
- manual hubs question
- Bypassing rear window relay, but still want it running of the ignition
- shortening wheel base
- Disconnected hose, is this ok?
- celica head in a 4runner?
- Blower motor problem after GM Alt swap
- engine cuts out at 4000+ rpms (22re)
- Starter problems!
- 1993 pickup won't start
- speedometer cable
- Windshield Washer Issue
- red LED guage pics???
- My a340h shifts at 4000 any way to make it hold gears longer?
- Loose shifter guild pins
- 3vze Head Gaskets what else do I need?
- tps adjustment
- how hard would this be?
- Ground issue
- Starter doesn't engage flywheel
- Is my oxygen sensor busted?
- 3.0 knock sensor..HELPPP
- Does my 93 runner have a stock front diff lock?
- blower problems
- New 22RE IAC Valve?
- Power Steering fails - Check your Reservoir!
- Mechanic's in Cleveland
- 22r choke pull off
- A/T oil temp light stays on always even when first started
- 32/36 Weber Man. choke or 38 Weber Man.choke for a 22R?
- Speedo swap
- head gasket or clogged radiator?
- Distributor, timing
- need help on rebuilding 22re
- Who wants to finally see homemade hoodscoop?
- Where to find white fender
- Extreme engine noise
- 90 22re idle
- Rocker panel protection
- Looking at first 4runner
- Hot idle/ restart rough idle and stall
- 90-95 4runner
- Electrical Starting Problem...I think
- 3VZE Ignition Timing Questions
- 3.0 head issues ongoing?
- suspreme suspension
- marlin rear bumper and motorcycle
- Check Engine Light?
- my truck lives!
- aFe Pro Dry S air filter doesn't fit
- My truck won't start. Please help!!!
- 3.0 V6 Timing Question
- 3vze hot start, ect?
- SR5 Gauges Work in 22R (carbureted)?
- Fiberglass Bedsides
- Old Man Emu Suspension Kit Installed....
- Heater Problem 22re no heat
- whats a longer drive line for a 86 long bed extra cab
- 87 22R - Still Have Rough Idle After New Carb
- PIC REQUEST: trimmed and cut 4Runner's
- My 87 Pick up build
- Heater Temperature problem
- new guy needs help!
- 1990 3VZE Upper/lower rad hose temp difference??
- Valve adjustment - DIY or shop?
- no power to ignition
- blower motor stopped working???
- need advice gettin my r12 system runnin again
- Wiring GM 1 Wire Alternator for 93 Toyota 4Runner 22RE
- Coolant & Bell housing
- Flip pac camper
