PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. throttle body 86 4runner
  2. first pickup! 94 sr5
  3. Truck shaking terribly at low speeds after U-joint replacement
  4. which lug nuts for pickup/4runner wheels???
  5. Piston Stop damaged piston 22re
  6. gages, windows and ac blow fuse 94 4runner
  7. You know summer is coming when Stacey gets waxed and Lindsey goes topless!!!!
  8. Electrical issues in 91 3vze 3.0 rebuilt eng.
  9. fuel pump problem
  10. A/C Diagnosis
  11. Brush guard?
  12. New timing chain touching new metal guide... clearance?
  13. 1991 Toyota 3VZE rebuild
  14. Blown Head Gasket
  15. 1992 4Runner 3vze 4WD M/T starts fine suddenly dies CEL flickers dim
  16. Missing this hose/connector. What is it? Temp control?
  17. Windshield Dilemma
  18. Pulling Out a 3VZE: How to Questions
  19. What's The Name this Hose?
  20. Fuel pump bracket interchange?
  21. bottom end power loss when engine is WARM - 22re
  22. Running rough!!
  23. Lesson Learned - Front axle & suspension
  24. Automatic Transmission Problem in Drive.
  25. Brake Booster Swap Woes
  26. Automatic Door Locks Giving Me Trouble!
  27. ext cab sub box.
  28. Replacing Tie Rods/ Idler Arm 2nd gen 4runner/Pickup
  29. 1991 toyota front end not engaging when put in 4x4
  30. brake problems...
  31. Which trucks came with map pockets?
  32. is my engine block a 22r or 22re?
  33. Flamethrower 3VZE Upgrade Injector Review
  34. Code 52 Knock sensor 3VX
  35. Need some help.
  36. Belts Singing Terrible Tune
  37. Shoes over tight; drums frozen on
  38. 93 4runner auto trans fail
  39. Got my first yota
  40. Snapped ENTIRE BVSV off at threads. Help!?
  41. Stock 87 4 runner questions
  42. Stumble/hesitation when cold
  43. bringing my toyota back from the dead with a v8
  44. 94 4runner 3VZE dirty fuel
  45. Bumper Swap
  46. a/c Compressor bracket bolt???
  47. need help
  48. auto tranny swap
  49. '88 4runner... help reinstall tailgate
  50. Will a 1998 Tacoma Transfer Case Fit My 1993 Toyota Truck?
  51. Cam Degreeing Question '89 22re
  52. 2nd gen 4runner longevity
  53. Rebuilt 3vze oil debate, my take on it.
  54. Brake master cylinder issues?
  55. Help!!! Yota pickup won't crank!! Please see video
  56. Spark Plug Change 3.0
  57. PAIR plug
  58. Help me identify this transmission leak...
  59. OME 2 inch lift springs
  60. ADD system troubles
  61. NEED HELP: Engine Knocks When Warm -Due for trip in two days.
  62. Engine Swap vs 3.0 Engine Rebuild
  63. removing/deleting A/C system entirely (22r)
  64. NEEDED~~~~~~~EGR Tube '95 22re
  65. 89 3.0 4runner -- Running Temp issues
  66. looking 4 U bolts
  67. Need a part
  68. Gauge swap for one with RPM in a pickup.
  69. Need quick fix for 1/4 panel wheel flares on 1988 4runner
  70. seat harness
  71. 95 4runner rear lift
  72. "88 22RE Won't Start
  73. Noise from a new water pump impeller.
  74. Flame thrower install / review
  75. 1991 Toyota cooling fan exploded
  76. Clutch hydraulics rubber hose
  77. 93 22re failed smog (2wd 5sp) CA
  78. 95 4runner 3vze Belt Alignment Problems
  79. 3vze redlined when throttle stuck, now noisey
  80. Electrician Needed Badly
  81. 1991 toyota truck running light
  82. Some Questions on Repair or Retire—Clutch/Compression
  83. So, I called the dealer...
  84. Idle trouble/temperature question (3VZE)
  85. 3VZ-E Injector Nozzle questions
  86. 1st Valve adj on a newly rebuilt 22re
  87. 88 2wd motor selection
  88. Steering stablizer question ?
  89. 94 3vze iac problem (no high cold idle)
  90. Dose the EGR sensor have polarity?
  91. Throttle Body replacement
  92. 92 4runner stall issue
  93. 3VZE idle / misfire issues???
  94. Rear Lock-Right & Carrier Question
  95. 90 toyota pickup
  96. 1995 3.0 Knock Sensor CEL
  97. will a manual gauge cluster work in an auto?
  98. lower balljoints
  99. Will a 2wd box fit a 4x4
  100. How To: Make a speedometer cable greaser tool
  101. need help with this 22r !!!
  102. codes and truck shutting down
  103. 1991 toyota shifting problem HELP
  104. Got a Truck and have some questions (video included)
  105. a340h to r150f tranny swap.
  106. tps swap
  107. 1989 Driveshaft stuck/rusted?
  108. 3vz oil light
  109. Steel timing chain guide catastrophic failure
  110. Adding AC to 1990 base 22r pickup
  111. Slower than should be stock 22re
  112. bottom end strength.
  113. Whats this part called ???
  114. 1988 toyota truck doors
  115. 87 Pickup window crank handle.
  116. Head gasket issues ?
  117. 3.4 swap/ best aftermarket intake..?
  118. Toyota Will Only Move in 4L.
  119. Tires n rims
  120. Finally, I hope, my truck will be back on the road.
  121. what alternator for 88 22re
  122. 1995 SR5 pickup....power relay issue?
  123. 93 extended cab driveshaft question
  124. 1991 toyota 2.4 RE EFI
  125. 94 No Power anywhere. Not Batt Or Ground
  126. 92- 3.0 V6 suddenly wont stay running! Ideas please?
  127. ! 92 3.0 V6- suddenly wont stay running- HELP please!
  128. Wheel Bearing's
  129. My first Toyota and I need help.
  130. Portland OR. 22re Motor and fitting
  131. Windshield wiper nozzle clogged?
  132. False over heating reading?
  133. Seatbelt replacement
  134. 92 4runner 4x4 3.9Liter Blown Transmission
  135. fuel pump questions,
  136. headlight trim
  137. CV Halfshaft ??
  138. gained boost in performace but have done nothing
  139. Clutch replacement
  140. Matching paint for grey interior.
  141. 3VZE only starts with pedal floored
  142. What is missing on this 22RET
  143. 1985 a340h trans replace into 87 turbo a340h trans?
  144. Wheel question. Need help
  145. Dash lights stay on.....
  146. good donor for v8/solid axle swap for 93 pickup
  147. 87' tailgate bolts?
  148. Ignition switch wire identification
  149. Oil in Rad but not what you think
  150. 93 4wd front disk
  151. need help with 4runner 3vze
  152. 22RE hard to start
  153. need help diagnosing
  154. Apparently a common problem, but need specifics
  155. tg sas pitman arm nut keeps backing off
  156. exhaust pro
  157. 22re pickup is Blowing Smoke
  158. need help de pinning the underhood fuse box 2nd gen 4runner
  159. 22RE Fuel Leak Test Question
  160. I need electrical help
  161. Bracket Identification 3VZE Pickup
  162. What $$$ to change out long block 3.0
  163. V6 3.0 oil pressure sending unit
  164. Bolts for the Alt pulley that connects to CS pulley
  165. 3vze hesitation
  166. 94 4Runner shutting down
  167. sprung door hinge
  168. Shows No Oil Pressure
  169. 22R A/C cycling?
  170. Where to get rebuilt W56B transmission?
  171. Need some help guys. Weird issue
  172. 93 22RE 4x4 decals needed
  173. Help Rebuild a complete FSM pdf (3vze & 22RE) (2 & 4WD)
  174. Seized Fill plug 92 V6 runner & Desperate! time running out
  175. Catalytic converter question?
  176. No blinkers
  177. 88 Toyota 22re Automatic Stalls when put in Drive
  178. Rear end noise while moving in gear and free wheeling
  179. 3vze Timing Belt / Water Pump / What else?
  180. is this a good rebuild deal
  181. Lucus oil stabilizer do or dont ?
  182. Conflicting info - what's the right 22RE oil pump bolt torque?
  183. Smog Troubles - CA blues
  184. ext. cab subwoofer box
  185. More Ticking!
  186. 91 pickup rough idle engine codes 25 26
  187. Fixing a poorly-cared for 86 4x4 truck
  188. Rebuilt 3vze issues
  189. OFF ROAD LIGHT wire arc and I'm an idiot, NO SPARK! I have checked everything
  190. Mechanical Speedo Issue '91
  191. 22re seized
  192. lift question
  193. Need recomendation for tires
  194. Shocks for BJ lift
  195. 5vz swap in 1st gen 4runner using T100 transmission
  196. 86 4runner tailgate/window won't roll down
  197. 3 vze Reman engine, distributor won't fit
  198. Which Brake Pads
  199. truck goes click click
  200. help identifying vacuum port 3.0
  201. 89 Pickup (22RE) Headlamp Switch Wiring
  202. 95 pickup 3vze running rough no power.
  203. 1991Toyota pickup bottom end
  204. 91 pickup with engine knocking
  205. Problem solving axle seal / bearing etc
  206. Windshield washer pump
  207. new here, need help with doors/parts
  208. 1990 toyota 4runner engine swap
  209. toyota girl needs help
  210. 88 Cab Visor
  211. Rebuild it or find a new motor????
  212. 22're radiator cap realising pressure
  213. When to change rear output shaft seal.
  214. 22RET engine pictures
  215. Normal Idle Speed
  216. Chrome Vinyl and clutch issues
  217. Very loud front end
  218. Problems with belt for alternator and water pump.
  219. Truck Bed 1987
  220. 88 3VZE Throttle Position Sensor Replacement
  221. 1990 toyota pickup 2wd exhaust reference
  222. Torsion Bar rubbing against frame?
  223. 22re high idle when cold
  224. What is this brake component?
  225. Stock Rim and Tire Question
  226. What is/how to tell the shock size for my truck
  227. Question on diff swap. NEED ADVICE.
  228. Major oil leak/head gasket blown
  229. 94 22re pickup plug wires
  230. 94 22re pickup pluh wires
  231. 86 toyota pickup check engine light
  232. 2wd w/Dana 30 swap for light duty use
  233. 1991 Pickup Instrument Cluster question
  234. 1990 rear shackle quesitons
  235. 4Runner Lift Kit Questions
  236. 90 3vze weird problems
  237. Gear-whine noise after new timing set?
  238. 94 v6 Sas
  239. idler arm replacments scrap on frame, cant get shorter one!!!!!!!!!!
  240. pitted block
  241. '87 4runner 22re efi swap to lexus IS300? will it work??
  242. Dash lights & Alt Brushes
  243. 22re running rough, whats new
  244. Seat mounts
  245. 93 leafs on 88?
  246. what the red part that sits on the axis Turk ?
  247. Joe gibbs break in oil
  248. Red oil light turns on when accelerating.
  249. Leaking oil from the axle, need recommendation
  250. Changed up my paint a little today.
