1991 toyota shifting problem HELP
Old May 4, 2014 | 11:58 AM
Dustin Egle's Avatar
So I just got done rebuilding my 3.0 v6 and installed a new clutch etc. I dropped the motor back in and hooked it up to my tyranny and everything it started right up and is running great. However, now it's a pain in the ass to shift! I get going and I have to really pull and force into gears. I've even gotten stuck in reverse and had to turn my truck off to get it into neutral again. My clutch is to the floor when I shift too. What's going on? Why isn't it working right now?
Old May 4, 2014 | 02:16 PM
HighLux's Avatar
Sounds like you need to bleed the clutch.
Old May 4, 2014 | 02:38 PM
JasonYota's Avatar
X2. Did you happen to buy a new slave cylinder and/or clutch master cylinder?
Old May 4, 2014 | 02:44 PM
No I didn't replace the slave or the master, just the clutch, pressure plate, and the bearing and flywheel
Old May 4, 2014 | 03:12 PM
Robert m's Avatar
Could the clutch disk have been installed backwards?
Old May 4, 2014 | 03:32 PM
No I got it in right, did it with a professional mechanic at his shop *my cousin*
Old May 4, 2014 | 04:32 PM
jreb10's Avatar
When you removed your shifter did you observe the condition of the shifter seat bushings? They tend to disintegrate in place. Perhaps a chunk or two are mechanically interfering with the shifter?
Old May 4, 2014 | 05:30 PM
Cyberman's Avatar
Try bleeding your slave. To me, stuck in gear means the clutch isn't disengaging properly. Clutch to the floor also sounds like the hydraulics need bleeding.
Old May 4, 2014 | 05:50 PM
Bleeding helped it! Thanks guys! Means a lot!
Old May 4, 2014 | 05:56 PM
HighLux's Avatar
Glad you got it fixed. Now you owe us pictures.
Old May 5, 2014 | 11:26 AM
Once I find out how to post pics, I will do that
zd92655
Mar 6, 2022 12:58 PM
Aleeex_u
Jun 5, 2016 06:52 PM
vasinvictor
Jan 20, 2016 12:39 PM
mtrdrms
Jul 17, 2015 02:23 PM
bprice0077
Jun 25, 2015 07:36 AM
