PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 [179] 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Part numbers for parking brake
  2. Which Red Top for a 92 V6
  3. locker?
  4. tuff country vs. skyjacker
  5. Rear axle swap
  6. 2wd vrs 4wd front fenders
  7. 2nd Gen 4Runner Tailgate Letters
  8. can you pass emmisions without the crap?
  9. HELP - 4wd after motor swap
  10. Heated air intake
  11. 2wd in the snow
  12. 89 22re to 94 truck swap help
  13. quick TDC question!!!
  14. 22r timing problem
  15. Speed Sensor
  16. replaing tie rod ends and pitmans
  17. Will a 90 trans fit a 94?
  18. 4wd actin weird
  19. 94 PU trans fill problem
  20. Quick oil pan question
  21. 95 SR5 4Runner V6
  22. 90 4Runner won't start
  23. w56 vs g52
  24. Wiper problem
  25. Cost to rebuild tranny
  26. running wires for a light bar???
  27. Transmission pan magnets
  28. Wab Fab front bumper
  29. Buying another Toyota, a question or two.
  30. Auto transmission wiring help needed
  31. who makes bad ass fender flares??
  32. My new 4x4 pics!!!
  33. downey fiberglass fenders
  34. Anyone ever buy from johns foreign aka 22re.com?
  35. Replacing front pinion seal
  36. Rear door locks lock themselves
  37. Can main bearings break and slip out?
  38. What's It Worth
  39. Grinding In front Wheel Hub
  40. No more hesitation
  41. Major loss of power, truck wont go faster than 30mph
  42. 00 Tundra rims on a 94 4runner
  43. is there a fuelpump relay
  44. quick timing question
  45. Elusive Gas Smell
  46. 22R carb question
  47. Hello take a look at my 4Runner
  48. Oil consumption-no smoke, good vacuum ??!?
  49. gears?
  50. Rancho Suspension System (making a return??)
  51. Auto Tranny Fluid Questions
  52. First 4runner, tons of fun!
  53. Did lots of mods and stuck one. the head
  54. Anybody See This Comming?
  55. Im leaking
  56. Rebuild the LPSV?
  57. cool 4runner paint schemes
  58. Ignition/starting problem
  59. No spark
  60. Wheel problem. Help.
  61. Tech Tip: FREE Starter fix
  62. BJ spacers; tire- UCA clearance
  63. Problem with a drive line vibration?
  64. What do you guys think of this 4runner?
  65. squeeling noise from speedo
  66. Not another exhaust question!
  67. Christmas came early this year...
  68. help me decide
  69. Odd Whistling Noise when accelerating... help me
  70. Uh oh....
  71. my 22re wont turn over
  72. Camper Top fitment
  73. tranny problem...
  74. Just ordered some Amsoil...
  75. switching from mechanic to electric fan ??????
  76. Treadwright M/T-G
  77. Im torn between the two
  78. 94 pick up....
  79. 4 wheel lock
  80. tailgate window motor
  81. Muddiest Rig
  82. how do you Tell if the m.a.f is bad
  83. Swapping Parts Between Pickup and 4Runner
  84. Coolant Temp Switch
  85. Do I need to mill my timing cover since my block was decked?
  86. Permanently locking the ADD unit
  87. Lost my Chiltons-what grease for u-joints?
  88. Volt gauge jumping
  89. Help on difference between old & new 3vze!!!
  90. Oil burning pos
  91. '95 3.0 Start when Cold
  92. 3.0 with a...wait for it...blown head gasket!
  93. power steering question.
  94. Igniter is diffferent on my toyota.
  95. 3.4 swap!
  96. 90' Pick up-Bizarre starting problems!
  97. handling in the snow
  98. chasis ground strap
  99. '86 4x4 getting hot
  100. Is this normal??
  101. 22re won't crank in cold weather
  102. 89 Pickup wiring nightmare
  103. neutral clutch switch
  104. Cool Toyota
  105. 3.4 swap or lexus v8
  106. what has everyone done to their center console?
  107. About to lose my mind
  108. How do these numbers sound?
  109. Auto to manual swap question
  110. header swap?
  111. 22R Aisin Carb Size
  112. Dropping IFS to get out oil pan
  113. so i am looking for a...
  114. I (nearly) totaled my 92
  115. Bad bearing in a 5 speed
  116. Starter contacts or brushes?
  117. getting out of 4wd
  118. I need to tap the yotatech brain trust yet again.
  119. Problems with starting the truck
  120. accidentally hit the clutch start cancel button now wont start up after off
  121. welder in vermont
  122. exhaust?
  123. newbie: HELP?? trading my 2wd for a 86 4runner!!
  124. Wobbling sound from front suspension.
  125. no powerat low rpms
  126. elocker?
  127. 22r block vs 22re block
  128. bad rod bearing
  129. Shock on top of leaf?
  130. Switches
  131. jusrt saw a weird tail light prob...
  132. how hard is it??
  133. wheres the best place for replacement parts?
  134. Newb needs help.any idea what this noise is....
  135. well, I think my head gasket's going...
  136. 5speed tranny question
  137. Before And After pics (Post Em Up)
  138. 22re Starting Problems
  139. 1993 toyota pickup 22r starting problems
  140. more power
  141. More fuel tank problems
  142. Budbuilt on the way
  143. Head liner, sun blockers
  144. high idle switch
  145. 2wd wheeling pics...more...
  146. Gen 2 FSM
  147. front dash speakers...
  148. Deckplate Type Mod for 3.0
  149. HG Replacement, Assembly Lube
  150. Rebuilt motor warranty Question????Please give advise
  151. auto trans, any good?
  152. 1992 22re swap to 1984 22r?
  153. should i rebuild my 22re
  154. Cross member bolt part number (post BudBuilt)
  155. injectors
  156. Cold start noise
  157. can you say WOW
  158. Power steering solutions...
  159. deciding on which cheap muffler to buy--opinions?
  160. auto tranny taking a dump
  161. What Water Pump?
  162. I'm buying a 4X4!!!
  163. Shaving heads
  164. straight axle
  165. ok so im stuck with a fuel pump problem
  166. adjusting TPS
  167. trying to gain some power!
  168. Wheel bearing question? Front left wheel seems to make noise
  169. 3.0 sounds like its knocking (non engine guy post)
  170. exhaust suggestions?
  171. Installing window trim gasket 89 4 Runner
  172. Sea Foam... do you want the truth?
  173. What brand A-ARM
  174. Lower ball joints
  175. gear advice
  176. Need ecu for 3.4 from a manual
  177. Manifold Gasket or Exhaust Problem?
  178. Auto Trans problems
  179. E-brake cable replacement?!
  180. key ignition problem?....
  181. drop in 3rds
  182. 22re for sale?
  183. My mini swampers!!!
  184. cleaning my engine
  185. Squeeling number 2
  186. A/C Tensioner Pulley Bearing Part #
  187. Clutch noise
  188. Have you done the Sea foam/ Mystery oil?
  189. altenator or belt?
  190. 1989 5 speed w/ transfer case 500 bucks, will it bolt to mine?
  191. 3.4l conversion for my 86 yota
  192. Short clutch pull
  193. Lifting the 'ol beast
  194. Whats my runner worth?
  195. 4" and 33s??
  196. rear suspension
  197. 22re Timing Question
  198. BFG KM2's any input?
  199. cat back exhaust
  200. NERF bars
  201. thinking about painting wheels can i have a little help
  202. Drive line question
  203. noise question
  204. Help! Starting Issue
  205. mpg's with the Supra MAF update.
  206. Headgasket job coming up...
  207. lcegineering air assembly
  208. 22re "studdeding/hiccuping"
  209. Using oil after switching to Synthetic oil
  210. Help I Cant Find My Starter Plug
  211. Truck wont start!!! HELP!!!!!!!
  212. Need timing answer quick
  213. Seat belts
  214. tc and deathcougar, need to pick your combined experiences
  215. anyone parting an 88? Somone stole my radio and half of my dash :(
  216. Soft clutch pedal
  217. 86 cab on 79 frame
  218. Rolled my Runner
  219. fuse help
  220. TPS wiring harness clip ??
  221. possible cv binding?
  222. 22re simultaneous injection? Explain Please!
  223. 88 Toyota 4x4 Looking to get better performance!!
  224. 2800 rpm at 65 mph?? Is that right?
  225. scored some loot today
  226. bucket seats for my yota?
  227. OK wtf?
  228. I found my trucks exact grandson!!!
  229. 1991 22RE Low Comp/Failed Emissions
  230. buying a 4runner with codes
  231. Tire PSI
  232. 90-91 bumper on my 94 4runner - advice please
  233. Ams vs regular vs synthetic oil
  234. 87 runner info
  235. 22re broken timing chain guide
  236. 22R Dipstick tube Removal/Re Install
  237. rebuilt 3vze Soooo Close to starting but won't
  238. Staling problem.
  239. u-bolt flip kit
  240. wipers don't work
  241. Driveline Vibration in Knoxville, TN
  242. leaving hubs locked
  243. found this on another site i belong to, aussies get the goodies
  244. Replacing Ignition Coil
  245. i could really use some help!
  246. '89 4runner V6 Sas Progress
  247. 94 p/u 4x4 3.0l 5 speed engine rattle
  248. burnout vid
  249. cop vs cluch
  250. Looking for tach need suggestions.
