No spark
Old Dec 5, 2008 | 01:36 PM
yz250_bm's Avatar
No spark
I new to this forum and have a problem with my 91 truck with the 3.0 v6. There is no spark. I've tried a different distributer, coil, igniter, and ecu from my parts truck and still no spark. The coil and distributer test ok and i've tried 3 different igniters. I have searched old threads and can't think of anything else.
Old Dec 5, 2008 | 03:18 PM
abecedarian's Avatar
checked your fuses?
Old Dec 5, 2008 | 03:57 PM
yz250_bm's Avatar
I tested the fuses and they were all good.
Old Dec 5, 2008 | 04:44 PM
Bigblock's Avatar
Gotta be the wiring in between all that stuff.Did you check to see if the injectors are getting their signal?
Bigblock
Old Dec 5, 2008 | 05:25 PM
is the coil wired up properly?
Old Dec 5, 2008 | 07:48 PM
yz250_bm's Avatar
Coil is wired up properly. The only thing I can thing caused this is when I welded together a battery tray. Also around this time I replaced the positive terminal because the old was trashed. I looked don't see where any wires were damaged. Maybe I should go make friends with a Toyota tech
zytra
Jan 24, 2019 03:16 PM
Kamaloha
Oct 16, 2015 05:13 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
Rcbc92
Sep 26, 2015 03:00 PM
