HG Replacement, Assembly Lube
Old Dec 2, 2008 | 11:12 AM
Whiplash Willy's Avatar
I am in the middle of a Head Gasket job on my 22re. I got my head rebuilt by ENGNBLDR for $130, which I though was a pretty damn good deal. Ted is a really good guy! Anyways, the head already has assembly lube where it should be, but I was wondering if and where I should apply the lube to the rocker arm assembly.
Old Dec 2, 2008 | 11:18 AM
TOYOTA 1's Avatar
put some on top of the valve stem, some on the rocker foot/pad.
and all over the cam/cam bearing caps/journals.
assembley lube is your friend
Old Dec 2, 2008 | 11:39 AM
abecedarian's Avatar
and don't forget to crank the engine over with the starter, and the distributor pick-up wire disconnected to prime the oil up to the top before actually starting it.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
crashburnoveride
Jul 10, 2015 06:39 AM
